F3s front drive belt sprocket
I have a f3s and have done 42000 km and in that time I have stripped two drive sprockets does any one else have the same problem or am I too had on the bike
Cheers
Allan
Are you using a belt tensioner?
No I use the cricket to get belt tension correct
Make sure theres no freeplay between the shaft splines and pulley splines,fit pulley with a spline loctite.use the latest high grade bolt and upgraded tension for the bolt.you should be ok.
