Results 1 to 9 of 9
    Nov 2018
    Pinawa, Manitoba, Canada
    Default Why is there a gap between nut and cotter pin on rear wheel?
    I bought a 2016 RTL last year and when I replaced the rear tire I noticed a gap of approximately .125 in. between the nut and cotter pin. Why not a castellated nut and cotter pin as two wheeled motorcycles use. I machined a washer that fits between the nut and cotter pin making it impossible for the nut to loosen.
    Yes, there is a gap. The cotter pin is not meant to lock the nut. Only to insure that is does not come off. With a castellated nut, the torque cannot be precise as you must line the slot in the nut up with the hole in the axle. Not very precise. I think this is why they went this way. Done correctly, the nut will stay put. I've not heard of a case where the axle nut has backed off. My personal opinion is that the cotter pin is a needless safety precaution. Maybe required by some DOT spec. or something.
    Odd, yes. But really no reason for concern.
    Nov 2018
    Thank you Ron. I asked my local dealer and they had no idea. Really like your swaybar it sure stabilizes the front end.
    Feb 2016
    Either way, the cotter pin is removed when you install a hitch...
    2020 RT Limited , Marsala Red
    Bossier LoUiSiAna
    Quote Originally Posted by Bikerman View Post
    sorry to hear dealer should very well know. Could have provided ANY# of better answers than “no idea” just doesn’t instill confidence with answers or comments like that might wanna test other dealers with same question
    May 2018
    Chateauguay, Qc, Canada
    I think it is there to prevent from losing the parts.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    I understand your frustration. But the reality is, dealers typically know very little about the products they carry. It is our assumption that they are experts that can really get us into trouble sometimes.
    So, to me, 'I have no idea' is a much better answer than what they usually do. Which is to make something up. The truth is always the better way to go. I'd much rather tell someone 'I don't know', than send them off in the the wrong direction with a made up answer.
    All-in-all. I think this dealer did the customer a favor. I would be inclined to go back there. At least they where honest.
    Jul 2010
    Las Vegas, NV
    I agree. Wrong answers are much worse than IDK!
    Joe Meyer
    Active Member Frostbyte's Avatar
    Nov 2019
    Florida
    As an old aircraft mechanic, I agree with the "Nut Retention" response. We used the very same technique on jets...Flat back nut with cotter pin or "Safety Wire" to retain the fastener without interfering with application of the correct torque. Think of it like the chain on your wallet. It isn't there to keep it IN your pocket, just to keep you from losing it if it comes out.
    Knowledge is the accumulation and remembering data.
    Wisdom is the effective application of it.
    [img]https://www.spyderlovers.com/forums/maps/map.png?
    2019 Spyder RT Limited , 2" brake pedal riser with wide pedal Phoenix Orange
