Results 1 to 11 of 11
    Mar 2020
    1811 S M St. West Belmar, NJ 07719
    Spyder Can't find the Horn/wires - 2019 RT Ltd
    2019 Spyder RT Limited Horn upgrade, can't find horn/wires.
    Found them, underneath the right front; drop the panel by the sway bar links, 1 torque 30 screw and 3 push pins.
    Its right there looking at you. Unscrew the nut & just observe polarity when you extend the wiring to your new horn.
    Last edited by Peter Aawen; 05-23-2020 at 12:28 PM. Reason: This is a "How do I?" question not a "How to do:" + Title clarificationdescription
    Danbury Connecticut
    Remove the left service panel. The horn should be on the bottom.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Mar 2020
    Hi, thanks for your response. but, its not there! Left service panel your talking about the Rotax panel?
    Danbury Connecticut
    Yes. That's where it was on my 2014. I don't know why they would have moved it.
    IBA #47122
    Feb 2017
    That's also where it is on my 2015 RT-S. However, it's buried deep in the left side beneath the fog light on my wife's 2012 RTL. I suspect BRP made a mistake and accidentally moved the horn to a rather more accessible location for a few years, then discovered the error of their ways and buried it once again.
    Jul 2014
    Mint Hill, NC
    Look on the right side, down low, sort of mirror image of where it was on the 14-16 MYs but a little farther inward toward the center line of the roadster. Look at the BRP online parts catalog for the Electrical System - Frame, https://can-am.brp.com/on-road/us/en...ts-iframe.html, and you'll get an idea of where it is. It was moved for MY '17.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Danbury Connecticut
    Quote Originally Posted by Arion View Post
    You know, your comment would be rolling on the floor hilarious if it weren't so true.
    IBA #47122
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Quote Originally Posted by ThreeWheels View Post
    "Where the heck is the gd thing on this beast?" .... Can Am owner's most asked question for the first year or so.(??)
    May 2018
    Jacksonville, Florida
    When I installed a new Bad Boy horn on my 18 RTL, I found the horn in almost the center behind the Swaybar. I installed my new one in the left side panel area where everyone said they were before. I ran the wiring to the other horn area and plugged in the new horn and left the original horn where it was at.
    Thank you,
    Ray B.
    These are the states I have driven my Spyder Rt Limited too.
    Mudflap -- Walmart
    Tricled Headlights and Fog lights -- valueaccessories.comRimsavers -- RimBladesUSA.com
    Showchrome Tiregard (TPMS) -- motorcycleid.com
    Front and side grilles -- CanAmSpyderAccessories
    Passenger arm rest -- Diamond R Accessories
    Rear axle caps -- Lamonster
    Magic Mirrors -- Lamonster
    Yellow and red running and blinker lights on fender --Show Chrome
    TRUNK-MOUNTED, DOUBLE FLAG HOLDER -- Rivco
    Rear Brake light for trunk -- Custom Dynamics
    Bumpskid w/led lights -- Spyderpops
    Seat cushion -- Airhawk
    Cup holders -- Drink2Go
    Ultragard-4-457BK-Black-Cover-Spyder -- Big Bike Parts
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    Speaking of horns does anyone sell something to stop the accidental bumping of the horn when trying to use the signal lights ?
    2018 RTL , dark blue
    Active Member scarecrow's Avatar
    Sep 2013
    largo, florida
    That's where I mound mine. I put two Caddy horns there.
    2014 RTS , Cognac
