Results 1 to 8 of 8
    Active Member INfox's Avatar
    Jun 2017
    TX
    Default spyderstore's dash mount: regular vs extended?
    Does anyone have the Steel Extended Satin Black Dash Mount from spyderstore.com? I am debating which one to order: the Steel Satin Black or the Steel Extended Satin Black.
    Thank you in advance
    2017 RT Limited Asphalt Grey with Lamonster RT Spyder Cuff; Lamonster FBB Highway Bracket; Kuryakyn 7597 ISO Trident Pegs; RoadSport Big Mudder Extreme, Magic mirrors, Airhawk R, plastidipped Frunk, Ram Mount Universal X-Grip IV Large, FZ-1 fuze block, Dual USB charger, BajaRon Sway Bar, Black Powder Coated RT Dash Mount Bracket
    Feb 2020
    N. Wilkesboro, NC
    I've got the SS No Glare in the non extended version. (I only have a phone to mount.) In hindsight, I should have gotten one of the black colors so it blended into the dash better but this works well. I'm not sure if I'd mount too much on this, though. I mean, it's well made but it screws into plastic. I have my phone mount laying on the dash or it wobbles around (6" RAM arm). Nice to have an option where the phone (GPS, etc) is closer to eye level. Lamonster needs to buy the rights to this.
    Dec 2018
    Long Island
    I have the dash mount. When I purchased it there was only 1 selection, steel satin black, so there was no decision to make. It works very well, I use it for my gopro but like that I have room to add additional devices.
    Jun 2017
    TX
    Thank you Monk and LongIsland,
    I am not planning to put on it much, just wondering about the max left side I could put my cam in. It looks like the holes are about four inches apart. The extended arm opening seem too close to the dash, I have RAM Double Socket Swivel Arm and I worry, I won't be able to manipulate the tie knobs.
    Mar 2015
    forrest above Reno, Nv
    I shamelessly copied JT's design in 6061 series aluminum and painted it black.... It has given years of non glare, sturdy service. I use a medium length arm to hold a Garmin 660 ( and an analog clock)with a strip of weatherstrip foam on the bottom. Eye level and works perfect.
    Lew L
    2014 RTS , Circuit Yellow
    Jul 2018
    Fountain Hills,AZ
    Any pics?
    Mar 2015
    Just go to spyderstore.com Mine looks the same but for one less hole.
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    I have this one
    https://spyderzone.ca/en/product/rt-mount-dash-bracket/
    Looks very similar in design and intent... this one comes with 3 B-size balls...
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
