Results 1 to 8 of 8
Thread: Genius or Sygic
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Default Genius or Sygic
    About to upgrade my 2014 RT-S to 2019 RTL (BRP Connect is Up-To_Date)
    Looked at all the Navigation programs out there. Have been using Garmin since that company first formed. Yeah a lot of years.
    After trying and experimenting not hooked up, FOR ME, I got it down to 2 choices.
    Genius & Sygic and "leaning" towards Sygic until a "real" test can be done.
    So, I would like to hear your thoughts on these TWO ONLY, please.
    I know there are others, I've downloaded them looked at them, and they were not to MY LIKING.
    So if those using Genius or Sygic or both could you chime in with what you like or do not like about these two apps, it would APPRECITED!
    Thanks Everyone
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Jan 2020
    New York
    Ive had our 2020 for a few months now and have used both. I think this will always boil down to a personal choice, but we found we liked Genius Maps better on BRP connect as it was easier to navigate and use.
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    Feb 2015
    Las Vegas
    Dynamic use will be the test for sure, thank you!
    2014 RT-S
    2014 RT/S , Black
    Mar 2019
    lakewood ranch fl
    I was not sure so I loaded both , like all the functions and look of Sygic but the map is small the menu takes a lot of the screen on the right side. for that reason i use Genius
    most of the time .If Sygic map were the same size as Genius it would be my choice .
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    Tried Genius on my 2018 RTL and HATED it... the screen seemed tiny, and spoken directions several times tried sending me on routes that were ridiculously wrong. Only used it on one 900 mile trip... glad I got a rebate card from the dealer that resulted in it not costing me anything. Have not used Sygic. Putting a Garmin on the bike this week.
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I tested both and selected Sygic for my 2020 RTL. Used it for a month and then purchased a Garmin XT. I'm so glad to have the XT, which is the best motorcycle GPS display I've ever seen.
    Good luck!
    Rob
    Quote Originally Posted by PaladinLV View Post
    Genius or Sygic
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Feb 2015
    Las Vegas
    Thank you, nice to know. Statically, there appeared to be little difference in sizing.
    Tnx spyderbear
    AJ
    2014 RT-S
    2014 RT/S , Black
    Nov 2018
    St Pete Beach
    I much prefer Sygic, last used Genuis a couple of years back when I first got my 2018 (so genius may be updated). I like fact that you can do a route online for Sygic, then place it on the Phone....albeit a little more work than it should be. To best of my knowledge, you have to do a single route Pt A to B on Genuis, then cause tweak it on the phone. Does not seem as easy.
    Above said, I have a Garmin 660 mount as well, very easy to get a route from a GPX file.
    2018 RT , Asphalt Grey
