Results 1 to 14 of 14
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    Default 2020 RT Radio Reception Issue
    It seems that the radio on my 2020 RT has little or no reception. I live in an area with tons of FM channels that the cheapest of radios can pull in. When I scan I lock onto just 1 or 2 radio stations. Does anyone else have this issue?
    It almost seems like the antenna is not connected....
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    May 2020
    E. Central Illinois
    Reception on my 2020 RTL isn't near as good as my 2015 was. Don't know if a different antenna would make a difference or not. Am not real happy about it. Guess BRP assumes no one listens to FM anymore.
    Mar 2010
    Derry, NH
    On my 2010 RT the FM reception was fine. How do you screw up FM radio? I was wondering if the antenna was the issue as well. I will look through the service manual to see if there is a connection point that I can pull apart and add a temporary antenna.
    The issues with this 2020 RT just keep piling up.
    Bob H - Derry, NH
    Active Member Papa103's Avatar
    Aug 2019
    Maine
    My biggest complaint with my 2019 RTL is terrible FM reception. I had an antenna booster installed, no help it might even be worse if that is possible. I'm not a fan of the GPS being linked to an app on the phone. Seems to be very clunky working in todays standard of GPS.
    2021 RT Limited , Marsala Red
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    The lock tight they use does cause some bad reception.
    I changed mine to the short one from Spyderpops.com
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    The reception on my 2020 RTL is way better than my other Spyders that I have owned and some of
    my 2 wheel bikes as well. May be you have a bad connection at the radio or antenna. Just a thought.
    Toby
    2020 RTL
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Quote Originally Posted by upsdoctor View Post
    ...I will look through the service manual to see if there is a connection point that I can pull apart and add a temporary antenna.
    Does this help?
    https://can-am.brp.com/on-road/us/en...ts-iframe.html
    Unfortunately, final search did not save. It appears that connections are combined, not making it easy to plug in an alternate antenna.
    May 2020
    New Mexico
    Quote Originally Posted by samewok View Post
    The lock tight they use does cause some bad reception...
    Is it blue, such as the common Loctite 242, which I understand to be non-conductive?
    https://www.henkel-adhesives.com/us/...ctite_242.html
    Over the years, there have been quite a few people complaining about the poor radio reception on their Spyders, and this has ramped up somewhat of late, especially since BRP went to the digital dash in 2018.... Since then, it seems to be a fairly common gripe, with those reporting getting good reception being the (apparently quite rare ) exceptions that prove the rule?!? Check out what the member who goes by the username Seattle has gone thru to try and get this sorted here:
    https://www.spyderlovers.com/forums/...ight=Reception
    Billybovine's experiences here:
    and Ride2gethigh's experiences here:
    But wait, there's more!! (Don'tcha just love a thread that keeps on giving?!? ) Just enter the word 'reception' in the Search field up the top right of your screen (just below Lamonster's logo??) then click on the box for 'Search Titles Only' and submit your search - there's probably gonna be at least 4 pages of results showing threads that could well be applicable, but you really want to concentrate on those from 2018 on - it seems the radios were 'upgraded' then to match the digital dash.....
    Jun 2010
    Las Vegas
    Quote Originally Posted by bodymanpainter View Post
    Toby
    I agree, no problem with radio reception on my 20 RT either.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2010
    Las Vegas
    Quote Originally Posted by SportsterDoc View Post
    BRP seems to use yellow loctite on everything. They’re like the old lady in the Tabasco Sauce commercial who says “I put that sh$t on everything”.
    2010 RT- 622
    Mar 2010
    Derry, NH
    Well I unscrewed the antenna today and removed the blue lock tight with a small wire brush. No increase in reception.
    On the next rainy day I am going to pull the Spyder apart and trace the cables out. I found the antenna on the electrical diagram from the service manual. Only two connectors to verify connectivity with an ohm meter Antenna Scketch.jpg I would also like to find an old car antenna to see if that helps.
    Bob H - Derry, NH
    Apr 2012
    Florida
    Radio works great on my 2020 RTL. Light years better than on my 2016 F3L. Tom
    2020 Petrol Blue Metallic RTL
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    The 2020 RTL I test rode for about an hour, the last half I played with the radio, and no problems with the reception.
    Maybe it didn’t get hooked up correctly. let us know how it ends up.
