F3s Auxiliary Lights/ Pictures? Necessary?
Debating on Auxiliary Lights for my Can Am F3ss. Wanted to see if anyone had any pictures with them on and if they like the look?
Go to Spyderpops or Lamonster Garage websites (both site sponsors). They show a bunch of lights available. And, they are mounted on Spyders, so you can see the look.
2022 RT Sea To Sky
I put the driving / fog lights on my F3-S. Don't know if I got a picture of it with the tupperware back on. Not necessary, but anything that makes you more visible is an improvement. The bright, driving lights are on any time the engine is running. They go on in the same mounting brackets as the ones that come OEM on the other models.
Lamonster Garage, easy install, better visibility.
I didn`t hesitate installing LED AUX lights for the visibility factor to be seen by others......no brainer if you wanna live.
I got the LED headlight bulbs, fog lights, and well jere you can see. All from Slingmods.com. All for visibility (and cool factor).
The smooth top fenders in the picture............. don't look stock. Are they modified or aftermarket? I like the look.
They are the Low Brow fenders from BRP. I found them new on ebay for a couple hundred cheaper than msrp.
