Results 1 to 10 of 10
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default FOBO and 2020 RTL
    Does anyone know if the FOBO tire pressure caps fit the stock valve stem and wheels on the 2020 RTL Dark Edition? I ask because I don't want to have to change my valve stems if I don't have to.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Yes I have them on my 2020 Rt
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    I have FOBO 2 on my 2020 RTL and RT622 trailer. The caps work with the factory stems, however FOBO recommends metal stems. They ship shorty stems with the kit, but they do not work with the Can Am wheels (too short). I ordered some from Walmart and had them installed.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Apr 2015
    Tucson, AZ USA
    Great, I just ordered from Lamonster.
    Rob
    Quote Originally Posted by samewok View Post
    Active Member Tec35's Avatar
    Dec 2019
    Rhode Island
    Quote Originally Posted by upsdoctor View Post
    I want to have metal stems installed for my Fobo 2. Do you have a link or model that you bought? Or any suggestions on which stems work best with Can Am Rims?
    2017 F3 limited , Black
    Dec 2013
    Quote Originally Posted by Tec35 View Post
    Why on earth?? Someone's gotta be having a lend of you lot!! These FOBO type 'valve top sensors' have been run for many years if not decades on 'normal' rubber type valve stems in other sectors of the 'pnuematic tire using world' without that causing any issues at all.....
    I've still got them on one of the 4WD's and both our bike's & I have more problems from water getting into them than anything else!! In fact, the ONLY times I've had any 'valve stem problems' & ended up with physically damaged or lost sensors has been when they were on metal valve stems!! Maybe we just treat 'em hard around here?!?
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Dec 2019
    Rhode Island
    Appreciate the feedback Peter. I was just going by the manufacture website stating that it could cause a blow out. I have never used these before. My mentality is why take the chance. There has to be a reason they posted the warning on the site and provided metal stems in the box.
    Mar 2010
    Derry, NH
    I have Napa p/n 90-416 metal valve stems that work with Fobo 2 on the 2020RT rims.
    Bob H - Derry, NH
    Dec 2019
    Rhode Island
    Thank you!
    Apr 2019
    Clinton, MS
    I think you will find that the Can-Am wheels don't have the 2 main problems FOBO is looking out for: excessively long valve stems that might bend under the weight of the sensor at speed and valve stems that stick out to the side that could encounter another part when rotating
Tags for this Thread
