Originally Posted by billybovine
On a 2016. The gps power plug is power through the radio. If your radio works the gps plug should have power when the key is on. I will assume your 2017 is the same.
That makes sense but I switched it on Radio and it seemed to work however in my metal building all I could hear is noise. I gave up and connected it to the accessory lever lock block I have behind the Air cleaner box. It works, I just have to have the engine running.
2017 F3 Limited
Zumo XT Nav Audio via Bluetooth
Originally Posted by Rattlebars
to see MY SPYDER PAGE
Detailed instructions on my page. I think the 2019 wiring is the same under the panel on the non-brake (left) side under the seat. There is also an audio jack there to put the GPS audio out. If yours doesn't have one, I tell you how to add one.
I have a 2020 Can-AM RT and just bought a Garmin Zumo XT. Bluetooth audio for music is awesome. Question: The navigation audio doesn't go through the bluetoothed speakers on the Can-am. Is this possible? It used to on my old Can-Am and Zumo660. It would interrupt the music and speak nav directions through the bike's audio.
Paul "Wingman" Metheney
2020 Can-Am Spyder RT Limited
On the 2020 the GPS doesn't go through your speakers. It's only wired for power and bluetooth through your headset.
i wired mind throw the aux/accessory under the top tupper ware
Troop, I'm thinking about adding a Zumo XT on my 2019 F3-S, any recommendations on mounting hardware. Photos of Garmin mounted on your bike?
Have you seen this ?
http://www.lamonstergarage.com/lamon...er-motorcycle/
IBA #47122
2020 RT Limited Asphalt Grey
Yes, that's the one I'm considering.
Your 2020 is not design to integrate a stand alone gps into the system. It is designed to work with your smartphone as the gps. With it you will get turn by turn directions through the Spyders speakers.
Options are.
Pair your headset to the gps. If your headset is capable of pairing with more than one BT source. Most are. Problem is the Spyder speakers will not mute when gps is giving directions.
Connect to aux cable. Either hard wire or BT receiver. Problem you cannot listen to music from radio or phone at the same time.
Give up on the Garmin and go with your smartphone. Either by plugging it in or BT only with the phone mounted on the handlebars.
2018 F3 LIMITED
Originally Posted by ThreeWheels
got this one on my bike love it
See item marked as GPS2
By chance do you know where I can find a diagram like this for the 2019 RTL?
Thanks in advance!
David in Wa.
2019 Can-Am Spyder RTL SE6
"The Ride is the reason. The destination is just the excuse."
Thanks in advance!
I got that from the 2018 F3 service manual. Service manuals are available for sale and download from multiple vendors.
If you are looking for the GPS power connector on your RT. I think it is on the right side instead of the left on a F3.
2018 F3 LIMITED
