Originally Posted by LarryC
I have the Federal Formoza tires. The po put them on it. I don't know how many miles they have on them, but they have lots of tread left. My only complaint about them is noise. They whine terribly! Any suggestions that might help the whine? I am running what the manual says for pressure, 18 lbs.
Another thing came to me. Are your tires mounted correctly. There is an inside and outside stamped on the tire. Look at the sidewall an see if it says outside on both. If not I would have them remounted and balanced.
When I had the federals they were noisy.
I will check for the inside and outside. I am pleased with how it handles, just wish the noise would go away. They are worse than the Dunlops used to be.
Federals are awesome on my RT....Best choice I made
