Results 1 to 25 of 29
    Active Member DaveMcC's Avatar
    Hamilton, Montana
    Default Federal Front Tires
    Tired of Kenda's price, mileage and poor wear characteristics. Looking for a replacement without changing the dimensions. Anybody have any experience with Federal Formoza AZ01"s. or any other brand? I have a 2013 Spyder ST LTD with 32K miles and I'm, sure there are folks out there with similar circumstances hoping to find a way around setting off the VSS but improving tire performance. .
    Quote Originally Posted by DaveMcC View Post
    " setting off the VSS ", it won't occur from any NORMAL size tires you can mount ( with OEM fenders ) - Period ..... I have read about every possible tire size combination for all Spyders ..... NONE ever caused a Code ...... Your size concern isn't a new question, it was figured out many years ago .... annnnnnnnnnnnnnnnd right now the best rated tire for any Spyder is the Vredestein Quatrac 5 ..... and they have the sizes that work on your spyder ...... Mike
    Sep 2014
    USA
    I ran the federals until the pothole blew out the sidewall.no others issues noted when used.
    Jan 2015
    southern WI
    I switched to the Vredestein Quatrac for the fronts. I really like em.
    2016 RTS , Pearl White
    Oct 2015
    Lynden, WA
    I just installed a pair on the front of my 2013 STS.
    WONDERFUL tires. Bought on Amazon for $43 each.
    Federal Formoza AZ01 All- Season Radial Tire-165/55R15 75V
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Nov 2018
    Claremore, Ok.
    I've got the Federal AZ01s on and they've been great on the twisties at twice the posted limit. My sons follow me on the two-wheelers and they're scared trying to keep up. My Nanny doesn't even complain.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I just put a set of Federal AZ01s on my F3-T. Absolutely amazing! I had a set on my previous F3 Daytona, but I put them on when it was new so I didn't realize how great they were. Now I ran the stock tires on my F3-T for a while but the handling just wasn't there. Decided to put the Federals on and it's a new machine!
    Great tires and a lot less money than Vredesteins.
    2020 RT Limited , Petrol Blue
    Invalid Emails
    Feb 2020
    Splendora TX
    Yah I bought a ‘13 RS in Jan. & decided to check pressures today, well front tires look to be a brand new set of Kendra’s of course, will run some of the tread down before replacing, but the rear was a brand I’m not familiar with, a Duplo HP1 205/55 15 (which surprised coming from a dealership)... was wondering if anyone knew of them & their performance ???
    Hamilton, Montana
    What size are you running?'
    Hamilton, Montana
    Quote Originally Posted by Mazo EMS2 View Post
    Invalid Emails
    Feb 2020
    Splendora TX
    They are 205/55R 15 , if you look up “tire size.com” there is a tire calculator there... this size is the same height as the 225/55R 15 & just 0.8 of an inch narrower... as I said it was on the cycle when I bought it from a dealer ???
    Invalid Emails
    Feb 2020
    Splendora TX
    There is also a tire speed calculator where you can put in the original tire size & speedometer reading then the size of a new tire and will calculate the actual speed @ that speedometer reading... have used it on my auto’s
    Hamilton, Montana
    Quote Originally Posted by jsflash View Post
    That's the rear tire. I'm ;looking for data on the front tires. But thanks.
    Invalid Emails
    Feb 2020
    Splendora TX
    Didn’t mean to hi jack U’re thread, still new to all this chat room stuff & just thought since you were asking about brand, I might find some info on the Duplo brand also... Sorry
    I bought the 165/60-15 for the front of my RT .... others here went with the 165/65-15 or 175/55-15 ..... prices vary a bit but all these sizes fit all Spyders so let pricing be your guide .... google it to find dealers in the Q-5 tire ..... Mike
    Jun 2010
    Las Vegas
    I have been running the Federal Formozas for years. They handle great the price is right, they will last 40,000 miles or more and they are asymmetrical so you can rotate them without having to unmount the tire.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2014
    Benson, NY
    Default Federals
    As you can see mine are performing very well.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jan 2015
    southern WI
    I am using the 165/60/15 Vredestein Quatrac on my 2016 RT. I wouldn't go any wider....they're GREAT!!
    Jan 2015
    southern WI
    165/60/15. I wouldn't go any wider.
    Aug 2012
    Central Coast, CA
    Another happy Federal Formoza customer here too. I had those on my old 2014 and was super happy with the results. They just plain work, and work well.
    2020 RTL SE6
    Mar 2016
    Payson, Arizona
    36,000 plus miles on my 2015 SM6, and they still measure 5 to 6mm on tire gauge, with even wear across the tread. 16 to 18 psi.
    Sep 2015
    Chilliwack, BC. Canada
    I’m running 175-55-15 Vredestein Quatrac on my ‘14 RTS and have about 2,500 miles on them and totally love them.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Jun 2020
    Rogers, AR
    I have the Federal Formoza tires. The po put them on it. I don't know how many miles they have on them, but they have lots of tread left. My only complaint about them is noise. They whine terribly! Any suggestions that might help the whine? I am running what the manual says for pressure, 18 lbs.
    Larry 2015 Spyder F3 SM6
    2015 F3 SM6 , Orange
    Sep 2009
    La Valle, WI
    Quote Originally Posted by LarryC View Post
    I have them on my 2018 F3L and mine do not whine. I put in 18 lbs also. Wonder if your alignment is off.
    2018 F3 Limited , Oxford Blue
    Aug 2012
    Central Coast, CA
    My Federals never made any excessive noise either. They were smooth and quiet.
    2020 RTL SE6
