Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Stupid Belt
    May 2018
    millsboro,delaware
    Angry Stupid Belt
    Just ranting here.I put a new Kanine rear tire on yesterday,that was the easy part.Setting the belt tension and getting the belt to ride where I wanted was way too much trouble.Seems like the slightest adjustment you make has it moving over too far.Seems like if they had to put a belt on it then they should have designed an easier system.Ive done this a couple times now and it never gets any easier.Rant over.
    : 2017 RTL ORBITAL BLUE
    Idaho
    Quote Originally Posted by spyder01 View Post
    For a long discussion of my travails getting the alignment just right go here. https://www.spyderlovers.com/forums/...m-amp-Question. I finally got it done. See post #14. There are several suggestions that may just help you. As long as you can get the belt to track between the flange and outside edge that is good enough. It moves as you ride and particularly it moves when you back up.
    2014 Copper RTS
    Jun 2010
    Las Vegas
    Was there a problem with your belt before you changed the tire? If not, you should have left it alone.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Idaho
    Quote Originally Posted by SpyderAnn01 View Post
    That's been said here many times, and for many not changing the adjusters has worked. But for some reason it hasn't for me. I've had to adjust the alignment every time I've changed the rear tire.
    Spyder01, Ann's question is directed at you. What was the reason you needed to adjust the alignment?
    2014 Copper RTS
    Jun 2010
    Las Vegas
    Mac, do you secure the axle adjusters with tape before you remove the axle? That keeps them from moving. We change lots of tires and very rarely do we have to adjust the belt.
    2010 RT- 622
    Aug 2007
    Greeneville, TN
    Belt adjustment can be a very pesky, and frustrating event. Dropping the rear shock bolt is a good start. Which I am assuming you did. Taping or securing the adjusters is also a good step. And maybe a bit of luck doesn't hurt either.
    Please don't forget to come back and give us your impressions of the Kanine tire. Many of us are craving that piece of information.
    Northern Kalifornia
    As you know, after you get your belt adjusted and as you torque the axle nuts down, the slightest movement of the a axle will make the belt move. To help reduce that movement always tighten the axle nuts in the direction against the adjusters. Hope that helps.
    Idaho
    Explain please. I can't figure out what you're referring to since bottom side of the axle nut moves in the direction against the adjusters and the top side away from them. In my case four years ago it was the top of the axle nut that pulled the axle away from the adjuster since it had more friction against the swing arm than did the bottom side.
    Last edited by IdahoMtnSpyder; 04-28-2020 at 11:54 AM. Reason: swap bottom and top
    2014 Copper RTS
    Idaho
    Don't remember that I did, but probably not. Remember, the adjusters only keep the axle from moving forward, not backward. If, like in my case, the axle nut wants to creep the axle backwards when you're tightening it, even taping the adjusters isn't going to prevent it from doing so.
    2014 Copper RTS
    Nov 2012
    Pueblo Colorado
    Chocking in front of the front wheels, and also using a Wedged chock up against the back of the new rear tire seems to help me, although I put a thin film of grease under the washers and try to only pull up on the axle nut to tighten. A bit of luck may be involved, and like all have said, I usually pull the shock bolt and roll the belt off so as Not to change the adjustors...
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    May 2018
    millsboro,delaware
    Ok Im back from work.What I did was this,I jacked the tire up by the rear shock bolt with a rubber pad to keep from stressing it.Then I walked off belt which was very easy.I put some tape on adjuster blocks and I also had some yellow marks on axlw washers to show where they were sitting on swing arm.BTW I checked belt tension while tire was still on floor and it wass 140lbs.Took off caliper pulled axle and went to 3 tire shops before I found one willing to do it.Put it back on ,never disturbing anything and the belt wanted to go way far left.At this point the fun began and ended a couple hours later.After a short test ride belt is at 160lbs and tracking in middle like before.I think the problem is keeping the right side fully forward.Someone said put a rod in hollow axle end and use tie down to put some forward pressure on it .Might work but muffler is in way.I haven't got enuf miles on Kanine to pass judgement,its smooth is all I know.
    Active Member DougE's Avatar
    Dec 2019
    Cambridge, Ohio
    I ran a ratchet strap through the rim and put the hooks on the foot pegs to pull the wheel tight against the adjusters. Tightened the axle and the belt runs right where it did before I changed the tire.
    2013 RTS
    M2 Shocks
    Yokohama Advan Fleva 205/55/15
    Vredestein Quatrac 5 175/55/15
    Viair 97
    2013 RTS , Quantum Blue
    Bryant, Arkansas
    Point of clarification ................... the belt is incapable of being smart or stupid, it relies on a human for that purpose.
    Anonymous
    May 2018
    millsboro,delaware
    Quote Originally Posted by DougE View Post
    That might work
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Here's what worked for me. I use a ratchet strap also, but not in the rim as I need to roll the rear wheel to see where the belt ends up on the pulley.
    The Spyder has a 5/8" (15.8mm) hole through the axle shaft. With the belt tension at ±175 Lbs (778 Newtons) there is very little chance the left adjuster will come off seat. The right side, not so much. So if you have a 1/2" (25mm) steel rod approximately 20" long you can slide it through the axle and hook a small ratchet strap to the rod protruding from the muffler side and find a pull point (front floorboard mount) to gently apply a few pounds of continuous tension frontward to keep the adjuster caps seated while tightening the bolt on the off side , holding the nut with an open end wrench, until good and snug. I also found a 1/2" drive Kolbalt 36mm standard socket on a torque wrench is short enough to actually get in by the muffler to do the final tighten. I tighten on the drive side first to snug it up, always pushing the wrench down or forward so as to not move the adjusters. Then I remove the ratchet strap and bar and using the torque wrench and short socket, finish tightening on the muffler side, always pulling the wrench up and/or forward on this side. You need to rotate the wheel several times to see where the belt will settle after the adjustments. I take the parking brake off and jack the rear off the ground to do this, and being lazy I use my belt sander to spin the rear wheel. Some folks run the Spyder in gear to do that, too much horsepower for me. Hand or belt sander is fine with me.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Sep 2012
    Stetson, Maine
    Another method that works well is use a wedge shaped piece of wood,(door stop) and wedge it between right side swing arm and tire. This keeps pressure on adjusters. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jan 2015
    southern WI
    Not to throw a wrench in the mix, but just to be clear that you are only spinning the wheel forward....? If you spin it backward, it'll throw the tracking off.
    2021 RT Limited
    2016 RTS , Pearl White
    Northern Kalifornia
    One wrench handle up, the other one down.
    Mar 2018
    Danville Ky.
    Pa i lived in fallentimber.
    2014 RT Limited , stock lamonster flat silver
    May 2018
    millsboro,delaware
    Quote Originally Posted by safecracker View Post
    I like this,seems easy
    Idaho
    Be sure to put it between the swingarm and rim like I show in the thread I link to above. The tire itself is flexible enough that the wedge being between the swingarm and tire will not absolutely keep the axle from moving.
    2014 Copper RTS
    Apr 2019
    USA
    Quote Originally Posted by Mazo EMS2 View Post
    From my experience only, you rotate the tire forward in the normal direction of travel to settle the belt. I shoot for the 1 credit card width, even though the spec is 1-5mm. You don't want the belt hard on the flange, but I like to run it close to the flange on the rear because (for my Spyder) the belt moves outboard when reversing. If you look at some videos of the belt running, they move about a bit when running normally.
    h0gr1der
    Idaho
    I've found it works best to turn the wheel in reverse for a little bit after the adjustment. Then turn it forward and check tracking. By running in reverse and then forward, the belt will settle in closer to it's true tracking position.
    2014 Copper RTS
    Northern Kalifornia
    Yes. you can rotate the wheel both directions but what you don't want is the belt walking off the sprocket in either direction.
