Results 1 to 24 of 24
    Mar 2015
    forrest above Reno, Nv
    Question Changing Fuel filter - what tupperware needs to be removed?
    Good day Gentleman,
    I'm planning on changing the fuel filter on the 2014 RTS. A question :
    What tupperwhere needs to be removed?? I've probably seen it in my adventures into the 's but I can't remember. I'll just buy a filter locally and I have the special clamps.
    Thanks all. Lew L
    2014 RTS , Circuit Yellow
    Northern Kalifornia
    Left side. Check out Cheap Cycle Parts schematic for your bikes year and model and it will show you where your filter is hiding.
    Active Member Gldwnger's Avatar
    Apr 2015
    Kitts Hill, Ohio
    On my 2014 RTS, The fuel filter is behind the frame by where the oil filter is.
    Northern Kalifornia
    Yea, it does appear to be on the right. https://www.cheapcycleparts.com/oemp...80/fuel-system
    Mar 2015
    Question fuel filter location?????
    As I'm preparing to do the HMC filter , I was going to R/r the fuel filter. It may appear to be on the right in the schematic but is not on the right side( maybe I need to clean my glasses). I'll be pulling the left side tupperware tomorrow. Hope the fuel filter will show it self.
    Lew L
    Sep 2014
    USA
    Check around the 41 minute mark for the fuel filter change. Its behind the frame. Same side as the HCM.
    https://www.youtube.com/watch?v=WTWmuSaDdB4
    Jul 2011
    Mitchell, Ontario, Canada
    Time to clean your glasses.
    Remember, Left and Right as you sit on the bike. Right side. You must remove the Right top side panel and rear side panel.
    Mar 2015
    After cleaning my glasses( thank you, billy and triker) BRP did hid it well.
    Thanks again.
    Sep 2014
    USA
    Yeah they did a good job of hiding it.
    Mar 2015
    Well ----- all done three filters replaced and different oil used. Fuel, trans, oil filters really aren't that hard ( if you know where to find them). save a lot of money by DYI.. BUT--- how much would a dealer charge to r and r those 3 filters????????
    Lew L
    Having DIY'ed my 56K service I will do it all again at 84K except the plugs; they're a PITA and I will probably stretch them because I used Ron's iridium ones. I just did things at my leisure over a couple of days.
    Sep 2014
    USA
    Would say over 500 bucks to do all those filters by a dealer.
    I have done all mine filters so far except for the plugs. Hope I never have to either.
    Member MrBill5491's Avatar
    Jan 2020
    New Mexico
    One question on the fuel filter, does one need to use the factory type clamps or can I use screw clamps instead?
    MrBill
    Las Cruces, NM
    Got Chile? Red or Green?
    2015 Spyder RT
    1980 Suzuki GS750ET, still scares me!
    I prefer to use the Oetiker clamps but you must have the proper size and the special Oetiker clamp pliers to do the job correctly. If you choose to use screw type clamps go to an auto parts store and get fuel injection system clamps.
    INDIANA, USA
    Default Fuel Clamps
    A big YES, Diffently use fuel injection type clamps.
    You really don't want any fuel leaks. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Dec 2015
    Oakley Utah
    Like this? https://www.amazon.com/HPS-Stainless.../dp/B093X2F9MW
    2014 RTL Platinum
    Those should do the job. You don't want to use clamps that dig into the hose.
    Jan 2020
    New Mexico
    Fuel injection clamps it is, thank you all.
    MrBill
    Las Cruces, NM
    2015 Spyder RT
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Yes right side above oil filter
    Dec 2015
    Oakley Utah
    Do you remember what size clamps for the fuel filter?
    And, how do these differ from pex clamps and tool used in plumbing, do you know?
    2014 RTL Platinum
    Pete, I'm sorry, I don't remember the clamp size or whether they are like pex clamps because my house is all copper plumbing. I do remember that the fuel filter and two clamps came in a pkg from Cheap Cycle Parts when they were in business and the three piece set was cheaper than buying three pieces individually. Look at reference no 27 in this link and you can see it's cheaper than the three pieces individually: https://www.canamoemparts.com/oempar...a4/fuel-system.
    Mar 2013
    I use Oetiker clamps also, but I do not have that special tool. I use an end cutter, but don't apply enough pressure to cut the clamp (it takes a lot of pressure to cut those clamps) never had an issue with them leaking.
    https://www.lowes.com/pd/KNIPEX-7-15...ers/1000698010
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2015
    Oakley Utah
    Quote Originally Posted by PW2013STL View Post
    Yeah it takes really strong hands to cut those off using hand tools. I've had to use a Dremel with a cutting wheel in the past.
    2014 RTL Platinum
