Results 1 to 7 of 7
Thread: Discoloring
    Active Member Micnice10's Avatar
    Jan 2019
    Rochester, MA
    Default Discoloring
    Just noticed this today 😞😞😞. Anyone else have this problem or better yet any suggestions to fix??
    Jun 2011
    Alamogordo, NM
    I don't see any problem.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Aren't most of them like that from the factory??
    Nov 2018
    Waynesboro, PA
    Depending on the material you can find cleaners that will clean and restore the shine. Like on the plastic when it gets dull and gray looking I use Mothers Back to Black on my RTL.
    My Spyder
    2012 RTL , Brown
    Quote Originally Posted by Micnice10 View Post
    Just noticed this today ������. Anyone else have this problem or better yet any suggestions to fix??
    Just a thought - after going for a ride of of + 1 hr. check the temp of those two pieces, I'm thinking the one around the wheel hub might be warmer. ..... if it is heat cycling could be why .... Mike
    Jan 2019
    Rochester, MA
    Makes sense! Thank you
    Sep 2019
    New Jersey
    Man that is one clean Ryker. Mine usually lot dirtier then that, therefore I didn't notice the discoloring. I have been using this stuff for years with great results. https://www.amazon.com/dp/B00KN0UOEE..._CUAPEbXC0FPDM
