Results 1 to 14 of 14
Thread: inflation
    May 2019
    PA
    Default inflation
    Please reccomend a tire inflator to carry when riding.
    Feb 2019
    Portland, Oregon
    Slime and others offer up kits that include a 12 volt compressor. Check them out.
    Active Member Elwood58's Avatar
    Mar 2012
    PHOENIX Arizona
    2012 Viper Red RT-S (Sold)
    2020 Ryker Rally
    2023 Plasma Red F3 Limited
    Sep 2019
    Gilbert, AZ
    Quote Originally Posted by Elwood58 View Post
    That is amazing.
    2022 RT , Petrol Blue
    Sep 2019
    illinois
    I carry an old 12v "Bell" tire pump. I modified it to plug in to the battery tender wire. As writing this I realized I have (2) 7.5 fuses in this line. I also carry plenty of 16 and 20 gram air cartridges. Does anyone know how many cartridges it would take to fill Rally size tires up to preferred psi. "Slime" may be nice but what about tire balance problems. My mechanic warned me that they charge an extra $20 per tire to clean out the mess.
    Mar 2012
    PHOENIX Arizona
    Quote Originally Posted by gr8Frank View Post
    That is amazing.
    We shall see. It got good reviews
    2020 Ryker Rally
    Aug 2019
    Stoughton, WI
    $5 at Walmart, but getting harder to find..
    2022 RT Sea To Sky
    Jan 2019
    North Carolina
    How do you hook that up to the Ryker (or whatever you are using it with)?
    2019 Can-Am Ryker 900 RE
    2019 900 Rally Edition , Black w/Yellow Panels
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by WilliamTRyker View Post
    I use this https://www.ebay.com/itm/12V-Battery...4AAOSwtEZdSUSC connected to my battery tender lead.
    2022 RT Sea To Sky
    Jan 2019
    North Carolina
    Do you leave that Battery Tender lead hooked up all time? If yes, do you tie it off or does it just flop around while you are riding?
    Aug 2019
    Stoughton, WI
    Mine is on F3-S, mounted in the frunk area..
    2022 RT Sea To Sky
    Feb 2019
    England
    Miles42 hi ref tire inflation I have a Draper cordless with digital readout / up to 150 lbs / with light . It reads tire pressure first , then you set it to what you want and it cuts off when reached € 54 from Machine Mart easy to connect to ryker
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    My dealer installed one on my Ryker before I bought it. I never even asked, they just did it.
    They have it so its even with my Ryker front grill. I used it this past winter for my battery tender.
    Jun 2019
    Florida
    Thanks for the info. I bought the same one but paid three times as much. Still a good deal IF it works and is durable. I bought a female cigarette adapter to battery tender connection so that I can use it without modifying the connection, in case I meet someone on the road that needs to use it on their car. It is so small that I can add a plug kit and fit it in a cloth bag to store in my little Ryker frunk.
