Results 1 to 6 of 6
    Mar 2020
    Cumming, GA
    Default 18 April ...Remove OEM passenger foot peg F3-S
    I was in the process of changing my F3-S oem passenger pegs to BRP footboards.
    I ran into a snag with one of the 5mm allen bolts holding the peg.
    One bolt came out with no issues, but the second turns but will not extract. All it does is turn and turn in place.
    I am in the midst of a FUBAR situation.
    Any suggestions as to removing the stubborn bolt?
    Thanks,
    Rotax
    Aug 2019
    Stoughton, WI
    Seems to be common issue. The right side pass peg on my 2019 F3-S won't stay folded up. The bolts are TIGHT. Since I ride solo, I just put a touch of black silicone in the pivot joint. That said, I'll have it addressed at some point while under warranty. Good luck in your endeavor.
    2022 RT Sea To Sky
    Mar 2020
    Cumming, GA
    Evening Troop:
    After further FUBRARING is decided to let the dealer handle the upgrade.
    Rotax
    Mar 2017
    One must heat them with a torch? Have you done so?
    Mar 2020
    Cumming, GA
    No
    can I just drive out the brass sleeve and install new?
    Active Member SpyderF3's Avatar
    Nov 2016
    Hummelstown.Pa.
    Quote Originally Posted by Rotax View Post
    No
    Lamonster has a very good video on removing those screws
