Results 1 to 24 of 24
    Vermont
    Default Question: Does the "1330" triple engine need a??
    HI All,
    During this pandemic (Covid-19) does the "1330" triple engine need to be put on a battery charger/maintainer?
    Since people are in a "Stay Home, Stay Safe/or Lock Down orders per there governors in there states & since people are not riding as much as normal.
    I am just putting this out there, because of the current pandemic.
    Under normal circumstances I wouldn't do that.
    I have a 2014 RTS-SE6.
    I am only looking for suggestions or ideas. Also trying help other spyder riders on this site.
    Everyone stay safe, healthy, wash hands, wear masks, practice social distancing, stay home. We will get thru this!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    A Battery Tender sure won't hurt!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Battery ...CHARGERS ... are different from Maintainers ..... read the directions on each and use accordingly ...... If I'm not actually riding my 14 RT it's on the maintainer .... I would only use a CHARGER, ( that has a meter built in ) to bring a battery up to FULL charge , then dis-connect and use a maintainer ..... A CHARGER can FRY a battery .... even the 1 Amp type / size ..... good luck ... Mike
    HI All,
    Deanna
    I know you had mentioned somewhere that your spyder was soon coming out of winter shutdown. I am guessing that you do have a battery tender hooked up for that.
    When we moved from AK to AR, it took over 70 days for the furniture and bikes to arrive. All three bikes were put on a truck with no battery tenders attached. All three started up first try. I am thinking you will be OK for the rest of the duration.
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    I have many of these for all my bikes, lawnmowers & generators and keep them plugged in (with harness plug to battery) constant when equipment is not being used. Have for years without any failures or dead batteries.
    Use them for sure.
    "BLUE STAR – She shines so brightly"
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    2018 RTL , Large Brake Pedal (cut 1/3 off). Oxford Blue/Chrome
    Vermont
    Yes, during the winter shutdown( Spyder) it was on a battery tender when it was in hibernation.
    Thanks, I am putting the suggestion out there.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    SoFlo
    If you have a true battery maintainer, then why not. If you do not have the correct type maintainer, then skip it.
    The correct type maintainer has a mode that desulfates the batteries plates.
    Aug 2019
    southwest oHIo
    The problem with that is that many people THINK they have the right type.
    SoFlo
    Quote Originally Posted by Steve W. View Post
    More correctly, many have insisted they have the correct type, and do not. Myself, I no longer even get concerned about what others are using or not regarding battery maintainers. Often here there is a Sheeple mentality, far better to read about what others use, then research and validate yourself for what is best for you. Belt tensioner / dampers are another sheeple topic.
    Apr 2015
    Green Bay, WI
    Baaa--Baa--Baa :-)
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Battery maintainer
    I've got a 2014 RTS SE6 and in the fall, after last ryde, I put the Spyder on a battery maintainer until spring. Last Sunday, 15 April 2020, I went out to start the Spyder, on the first push of the button it popped right off. Hope this helps.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Nov 2016
    Upstate NY
    I have found that the Battery Tender Jr pictured in the above post, works flawlessly. It is also available at Walmart and everyone has one of those near them. Mine was located near the air compressors in our store, not near the car batteries.
    Jun 2017
    Rapid City, SD
    Hey Joel your ride looks sharp! Back to topic...
    HE>I
    2017 RT , Asphalt Grey
    Vermont
    I use the Battery Tender JR. 12V 750mA, 1.25A. Can be used for all outdoor vehicles.
    Automatically switches from full charge to float charging mode,
    Reverse Polarity Protection to ensure user safety-Red & Green lights alternately flash in this condition.
    Spark proof,
    Correctly Charges and Maintains all flooded AGM,Gel, and sealed maintenance free batteries.
    I also have a 2014RTS-SE6 when the spyder goes into winter storage in the fall, it goes on the Battery Tender Jr. then in the spring when spyder comes out of hibernation it also starts right up, and I am ready to ride!
    I have been using the above since 2012.
    I am just putting this out there.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Spark proof,
    Deanna
    YUP! I have four of them and counting. Only needed one for the John Deere this winter though. Bikes never were on chargers this year, there was no winter layup.
    Aug 2012
    Central Coast, CA
    2020 RTL SE6
    Jan 2015
    southern WI
    Quote Originally Posted by MeudtPG View Post
    Use them for sure.
    ^^^^THIS^^^^ Deanna. I use them on all of my power equipment. They "maintain"...in other words only slowly charge when needed. And yes, if your bike is still gonna sit, you should hook one up. My guess is the dealer had it hooked up during storage
    2016 RTS , Pearl White
    Vermont
    Quote Originally Posted by Mazo EMS2 View Post
    MazoEMS2, Yes, I do use the Battery Tender Jr. 12V. It maintains a charge/and switches to automatically floats.
    Yes, my bike will continue to sit, and I'll hook it up. The dealer did have it hooked up when in storage during the winter months.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    I have had 4 spyders and I stored them in the winter months. I have never used a charger or a maintainer on any of them. They start right up in the spring.
    Vermont
    Quote Originally Posted by ndspyderlover View Post
    What do you use to keep the battery charged in the winter months?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2012
    fargo, north dakota
    I do not use anything . I just start it and ride.
    Vermont
    I see you are from North Dakota, so you must get the cold/ and snow in the winter from the great lake?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2012
    fargo, north dakota
    We are not near any great lake. I disconnect the battery n the winter.
    Vermont
    Ok.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
