Results 1 to 13 of 13
    Active Member Spyder Hawk's Avatar
    Feb 2015
    California
    Default Installing center and rear front fender lights
    Hey group. Question for the electronics gurus out there. I'm putting the center and rear front fender lights on my ST-S and all I can find online are instructions for the RT. They say to remove the headlight and tap the line for the marker light. Problem is the ST lights are not removable in the same way as the RT and don't have a marker light. My marker light is in the front fender. Can I tap it from there and just run the power wire up to the blinker to get the secondary blinker effect? There is no video on line that I can find and no threads to speak of.
    Mar 2013
    Maumelle, AR
    If you want to have your lights just as running lights, get your power from your marker light on the fender. That's a pretty easy job. IMHO, that looks nicer (less busy) than when they flash opposite your turn signals.
    2020 RT Limited , Chalk
    Bossier LoUiSiAna
    Quote Originally Posted by Spyder Hawk View Post
    please share pic when done and yes can tap on the fender marker lights & snake around I did when installing the tric rings for fog lights tapped to opposite side for each to eat up the slack & keep clean. (Just lil things I may do differently)
    & now the rings are same as driving lights & the SpyderPops LED bump skid
    Current driving lights:E0ADA38D-2CE0-49A4-8922-CEC4911DA22D.jpg as far as blinkers go, the fender blinkers are tapped to each blinker at the mirrors
    Oct 2015
    Lynden, WA
    Hope this helps. 5 pages of instruction for installation of TricLED Fender lights.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Jun 2014
    Schenevus NY
    One thing to add to the instructions Haze posted. Once you take the top piece off the fenders you'll see there's very little slack in the existing wires to the front fender light and there's very little room to include the wire taps that Tricled provides. Also the taps don't provide a good, solid, water-tight connection. When I did it, I had to take it all apart and re-do it, this time using soldered connections with liquid electrical tape and shrink wrap tubing. It's more work but the top fender piece fits correctly now and it's a good, solid connection.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Feb 2015
    California
    Thanks guys. I did one side before I saw these post, lol. Those directions are so much better than the ones I got, thanks Haze. It sucks that, for what they charge for these things, we can't get directions for the ST. You are right Trbayth they don't make a good connection. If I had some T-Taps I would feel better about it. I'll probable have to re-do it later.
    Feb 2015
    California
    I ended up doing the same as Trybayth did. I tried with the existing directions and supplied connectors...waste of time. I went for my own setup and did it in a way that made sense to me. Thanks guys for all your help. I put a pic in of what I did but I don't know if it will show up.
    Bossier LoUiSiAna
    Feb 2015
    California
    Thanks Bfromla. It was an experience that is for sure.
    Oct 2015
    Lynden, WA
    DIY is a challenge but worth the effort.
    Nice job.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Mar 2015
    forrest above Reno, Nv
    I have the sequential fenderz lights from TricLED and they are DEFINITELY worth the effort . Very bright and eye catching.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    +1 on the Sequential Fenderz...and here is a video (late for you, but maybe useful for the next person)
    https://www.youtube.com/watch?v=sgAk...ature=youtu.be
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Feb 2015
    California
    Thanks for the info Raprider.
Tags for this Thread
