I have a massive magnetic pull. Screws and nails leap at the opportunity to imbed themselves in on both of my tires! Plug kit, Aerostich compressor, and problem solved. The nails and screws stay imbedded, making them easy to see. Or, soapy water, poured over a filled up tire. Typically, you are miles from anything, so, take your time! Once you find the puncture, fix it. I usually replace the tire when we get where we are going, or, if none are available, when we get home. The idea of fixing a tire with a Phillips head screw nearly had me, as I thought it was in jest. I hope it was. If not, very scary!
No jest. The screw will not go anywhere. The Fix a Flat seals it tightly. And why would it be very scary. I am not saying everybody should do it, because someone would screw it up and blame me. It works for me, that's all that matters to me. I just shared it.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
