Results 1 to 14 of 14
    Oct 2011
    Canada
    Default 2020 RT Panel Removal
    Im trying to access Gps plug on the right side. I am unsure how to remove the panels to get to it.
    Is there any videos or instructions how to do it? Ive searched the forums with no luck.
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    Send me your email address in a PM and I will send you the instructions.
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    May 2013
    Edmonton Alberta, Canada
    Quote Originally Posted by upsdoctor View Post
    Why don't you post it here and share it with everybody?
    2014 RT-Ltd , Cognac
    Jun 2010
    Las Vegas
    Raise the seat and you will see a label that says PULL, pull that then work your way pulling the panel towards the front of the bike.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2016
    Albany NY
    May 2013
    Quote Originally Posted by TIMMB View Post
    Not one of his better how to posts.
    Though he does take off some panels, he doesn't explain how he took them off...
    Houston
    I have read the BRP service manual through a few times and it does not explain the order or exactly where the fasteners are located. Screws yes, but not the pull apart connectors. Just looking at the number of body panels held by push tabs, these are going to have broken tabs as they age due to the number of them involved in service. Those wedge tabs are not intended for multiple use removal and reinstall at every oil change.
    I await a training video to explain the sequence and position of all the tabs. It will get sorted in time.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2013
    Maumelle, AR
    https://www.spyderlovers.com/forums/...ear-Electrical
    Watch this for the rear panel removal.
    2020 RT Limited , Chalk
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Email me at robhowen@gmail.com and I'll share the pdf that I created. It's too large to post here.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Oct 2017
    Apple Valley, MN
    Bob H.
    I saw that you listed "Garmin 590 with BRP Mount" as one of the options that you have.
    I purchased a 2021 and wondering where you made your purchase?
    Please Advise Bob G.
    2014 RT Limited , Wide Brake Pedal Lava Brown
    Mar 2010
    Derry, NH
    I purchased mine from the dealer
    Bob H - Derry, NH
    Sebring, FL
    Egads, looks like a job for NASA.
    Aug 2020
    Georgia
    To get to the gps plug on the right side you only need to pull 3 pieces of tupperware and 2 of those pieces are small and just pull off by hand (clips). The long piece that stretches up to the front by the frunk is held with 3 large torx screws, 2 push pins and several clips.
    I have removed all 3 pieces numerous times on my 2020RT and it takes me about 7 minutes now. Putting them all back on takes about 10-15 minutes because I have to fiddle with that long plastic piece up around the shock absorber mount where there is a clip which always eludes me ......
    Invest in push pin puller pliers ($15-20) if you are going to do much work on your Spyder - it will save you a lot of time.
    Sep 2020
    Middletown, NJ
    The best video I've found for RT rear end removal is here:
    https://www.slingmods.com/canam-spyd...cled?vehicle=1
    Thank you Slingmods!
    2020 RT base , Chalk White
