Results 1 to 21 of 21
    Aug 2019
    Neskowin, OR
    Default Best grease to use for lubing suspension
    So what is the best grease to use to grease the suspension on my 2013 Spyder ST ?
    Oct 2015
    Lynden, WA
    I use automotive grease-moly lube.
    Sorry I don't know the brand.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    May 2018
    millsboro,delaware
    Where are you using grease on the suspension,I have a 17 rtl and I dont think ive seen any grease fittings.
    : 2017 RTL ORBITAL BLUE
    Oct 2014
    Fort Mill, SC
    A warning about grease! Not all greases are compatible. Grease is oil in a base thickener.
    This is an excerpt from an article I found:
    David Turner, of Shell, stated it well in the January 2009 issue of Machinery Lubrication:
    In bygone days, when simple soaps and clay were the primary thickener types,
    compatibility was relatively straightforward. Lithium and calcium soaps were compatible
    with one another, and neither was particularly good when mixed with a clay-based
    grease. Today, with not only the aforementioned thickeners – but also complex soaps,
    polyurea, calcium sulfonate and even more exotic thickeners used in many greases – the
    issue of compatibility has become much more complicated…To add to the confusion,
    there are some grease specifications that are based solely on grease performance without
    regard to grease composition. If greases of different thickener types (both of which meet
    the performance requirements of the specification) get mixed in service, dire
    consequences can result.
    When you mix incompatible greases, one of three things happens:
    1. Nothing. Everything is fine.
    2. The base thickeners dry up and turn to a concrete type material. Not good.
    3. The base thickeners dissolve and release all the oil. Not good.
    You need to know what grease was put in at the factory and then use the same type or something compatible.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Mar 2016
    n.c.
    What fittings? Ty
    Oct 2015
    Lynden, WA
    Thumbs up
    Thanks for the reply. Only on the early Spyders. Mine is a 2013 STS.
    There are 8 zerks. The pesky fittings are almost hidden.
    The zerks are on the frame end of the upper and lower "A" Frames not at the ball joints
    See the Upper Left illustration. Part #11 on the illustration.
    https://www.cheapcycleparts.com/oemp...spension-front
    David C
    2016 F3T
    Rear IPS Pack Rack
    I use a fully synthetic grease from Amsoil. Fully synthetic grease is thinner than the standard mineral based greases at room temperature that I have used before. I was surprised that the synthetic grease was thinner. I really expected it to be thicker. At first I thought this might be a disadvantage. Thicker is better, right? But what I learned is that the thinner grease more easily reaches all areas needing lube. Places that thicker grease may never get to. Also, thick grease tends to thin out quite a bit in higher temperatures. A true, fully synthetic grease maintains original viscosity in higher temperatures. So while it may start out thinner, synthetic grease does not get any thinner in heat. Nor does it thicken much when very cold. It will not separate, dry out or wash off like standard grease can. It is also better at preventing metal to metal contact.
    It costs more, of course. But it also lasts quite a bit longer, requiring fewer applications over time. I know the 8, A-Arm bushings on a Spyder are a pretty important component to grease. I had to replace all 8 of mine due to wear. The early bushings were engineered poorly and grease was not reaching the back side. They would run dry and wear. Never had a problem after switching to a full synthetic grease.
    Oct 2015
    Lynden, WA
    Thumbs up
    Thanks Ron.
    I will be switching to a full synthetic grease.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Quote Originally Posted by Haze View Post
    Thanks Ron.
    I think it is worth it. Especially for the small amounts required by the Spyder.
    Sep 2014
    USA
    Been using Synthetic grease and oil for years now..
    Active Member DougE's Avatar
    Dec 2019
    Cambridge, Ohio
    I have been using Mobil 1 synthetic grease for many years now. It has always worked for me.
    2013 RTS
    M2 Shocks
    Yokohama Advan Fleva 205/55/15
    Vredestein Quatrac 5 175/55/15
    Viair 97
    2013 RTS , Quantum Blue
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    Holy Cow!!!! I have never tried to do this myself, but admit I have a shop do my oil change. I wonder if they grease these fittings????? Can you "get there" with a regular grease gun?
    Quote Originally Posted by fulltimer View Post
    You can get there with a regular grease gun, though one of the small cartridge guns with a flex hose and (for some connections) a side mount head can help. It has been my experience that you can't count on the dealer lubing zerks during a maintenance/service visit like they should. The bushing design was improved on the 2013+ A-Arms. But still, it's a very good idea to lube them. You will not be able to maintain alignment if they start to wear.
    Mar 2016
    n.c.
    OK....I have looked n I cant for the life of me see any fittings. 2014 ST SM5
    Mar 2016
    n.c.
    OK....Done a bit more reserch AND....The 2014 up models dont have fittings. No wonder I could not find em! TY ALL for the info on this site.
    Apr 2014
    OK Ron. Now you have shamed me. I'll have to go crawling under my '13 ST-L and find those fittings. But thanks. Really. I have 49K miles on my spyder and based on tire wear, I still have about perfect alignment. I'd like to keep it that way.
    My purpose is never to shame anyone! But I know what you mean. Not much is mentioned about those A-Arm bushings needing lube. I do mine with every oil change now. Probably overkill. But if you have to replace them, overkill doesn't seem so bad!
    Apr 2014
    Just pullin' your leg a little Ron. But still shame on me for not even knowing they exist and making sure they were lubed at least every other oil change. And overkill never hurts.
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Ron, I am getting ready to replace the bushings on my 08 GS.
    I ordered OEM parts from Cheap Cycle Parts.
    What is the difference between the original bushings and
    the newer ones that isn't designed poorly?
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Quote Originally Posted by YPILOT View Post
    It may be that the bushings that you are getting have been redesigned. Maybe not. If I remember correctly, the re-designed bushings had a an angle split in them. They were not a solid piece. Presumably, this angle split helped distribute the lubricant better than the original, solid bushings. Something similar to this.
    It has been many years since I did this. So my memory may not be stellar on this one.
    Dec 2019
    Land of Lincoln
    Redline CV-2.
    https://www.summitracing.com/parts/r...kaAudZEALw_wcB
    I agree with Baja on all points about synthetic grease.
