Results 1 to 15 of 15
    Jul 2016
    Minnesota
    Default Trying to decrease front dipping/scrapping.
    I have a 2018 F3 limited. The front end scrapes at times going in and out of gas stations, parking lots and some times pull over spots. I know others have experienced similar.
    I so far just have the stock tires and shocks on it. The manual says max tire pressure for fronts at 17psi and I have mine cold at 16.5. Can I go higher and would it help the scrape problem?
    My other thought was tightening the front shocks a bit? Hubby says it is easy to do but in doing so it could change the alignment?
    Just trying to think what may help. BTW my tool kit doesn't have the shock adjuster wrench in it... Did I loose mine or did it not come in the tool kit?
    Thanks for the advice
    The first thing I would do is be certain that when entering/leaving the places you say where your F3 scrapes is to approach/depart at the sharpest angle possible so that both front wheels don't hit the dip at the same time. I have to do that leaving my driveway and it works every time. I doubt that 1/2 lb psi increase in front tires would solve the problem but there's know harm in trying.
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    I think most of us just got a 'bump skid' from Spyderpops and don't worry about it much any more.
    T.P.
    Oct 2014
    Fort Mill, SC
    with Jaybros. That includes speed bumps.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Check your ride height empty (nose to floor measurement). Then check your ride height with whatever loading you have when you are experiencing ground strikes. If the ride height is significantly less loaded, I would suggest getting spring pre-load adjustment on your shocks. With pre-load adjustment capabilities, you can maintain original ride height no matter what the loading. It also helps compensate dynamically for the additional mass which tends to make the front of the Spyder dip more severely than it should.
    There are a few different ways to achieve this adjust-ability.
    Jul 2019
    UK
    Does your F3 have adjustable rear shock? Because lowering the rear lifts the front.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
    Jul 2016
    Minnesota
    My rear shock is self leveling. Rear tire is at minumim psi per manual. Measured clearance on flat surface and it is 3.5 inches. With me sitting on it hubby stated "way less" (I think he was afraid to tell me the clearance like it was my weight or something... lol... ). So we definately need to tighten the suspension.
    Hubby was wondering if the sachs shocks are reverse threaded?
    Thanks for the advice on taking questionable ares at an angle. I also have found it helpful to do all the breaking before the area.
    Dec 2008
    Jacumba, CA
    My suggestion is to watch where your going, slow down for driveways going in or out and stretch your angle more.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    hi paula
    i have a 2016 f3 lim and the distance from ground to the top chrome point is 380mm
    this height on my bike is standard for under chassis clearance
    if you need more clearance then,as baja ron says,you can adjust your shocks to suit
    when you wind your shocks up,you will not affect your wheel alignment
    but you will affect your camber
    here is how i measure camber
    take a square board(anything really)and place next to wheel
    then measure the distance from the bottom and compare it with the distance at the top.....if top distance is greater,then you can wind the shock up more
    wind up until both top and bottom distances are equal then stop(the left shock affects the right side camber)
    more weight on the bike will give -ve camber...eg top lays in(you can jack the bike up more)
    once the front wheels are square(at 90 degrees to the ground)then you cant wind the shock up anymore
    some people wrongly assume that winding up the front shock will stiffen the ride
    what it does in reality,is to raise the front of the bike
    hope this helps
    russ
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
    SoFlo
    Quote Originally Posted by merlot View Post
    hi paula
    hope this helps
    russ
    Sorry Russ, Can Am Spyder are notorious for bump steer effect. Any raising or lowering of the chassis will induce a toe change, which is a change in alignment.
    Adding spring preload does not change spring rate, but will change spring force at full extension, full compression, and intermediate points.
    You are correct. Though there is a range within which alignment is not seriously affected. That is why I recommend maintaining ride height instead of lifting the front of the Spyder. Of course, when you maintain original ride height, you are 'Lifting' the front of the Spyder from its collapsed state when loaded. It's really a very simple concept. The combination of recovered ride height (increased effective ground clearance) and stiffer spring action reducing downward movement when contact is made with an incline, makes a huge difference. It increases stability and usually eliminates ground strikes even if you are not careful.
    May 2018
    Morriston, florida
    Paula, have you found an answer? I have the same yr model spyder and SAME problem. We always ride 2 up. I tried to lengthen shocks but could not break the adj. Nuts free. I do have skid plate because the botton of nose was getting torn up. From skid plate to road i have 2.95 inches clearance. Not enough.
    Have you solved the problem?
    Active Member mully's Avatar
    Jul 2018
    Harrison, wisconsin
    taller tires?
    2018 F3s, 2016 versys 650LT, 2001 concours 1000
    Sep 2018
    Australia
    Quote Originally Posted by Paula View Post
    .... > snip < .....
    No but the locknnuts are very tight you need a couple of c spanners to crack the varmints.Amazon has heaps.
    Quote Originally Posted by mully View Post
    taller tires?
    Really not necessary. Adjusting the shock pre-load to maintain empty ride height is all that is really needed. It not only recovers lost ground clearance. It also reduces suspension collapse when hitting a bump or inclined surface like a driveway approach.
