Originally Posted by ISPYD
Who put the General on? The dealership here will not put anything on but what they sell
My Dealership installed the General Altimax RT43 tire, and I signed a wavier.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
That tire looks almost brand new.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
Originally Posted by sduskin
I put this Kumho on my rear several months ago and it holds curves/corners very well and I tend to push it when I ryde, but I haven't done any twisties on it yet. I'm itchin' to get out and start twitchin'.
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
This tire looks like the new one my dealer installed. I looked at it and said it is down to the wear indicator already, how do you know when it is worn out? When you get down to 1/2 the centre indicator is usually when people change them out. Did that on the first tire 9,000 miles, now getting down to half again but used mostly 2 up 5,000 miles. Last tire buying from dealer, will also be buying an aftermarket. I used to teach mechanics, the indicators they use on their tires are worst I have experienced. Love the Spyder's operation, but some of the information supplied by BRP and the dealers is questionable.
Originally Posted by nightcruiser
why 215?
For rear tire size? Because very, very, few car tires are manufactured in the 225/50R15 size. 215/60R15 fits nicely.
2014 Copper RTS
Ozzie Ozzie Ozzie
There is that! ^^ Aaaand, being ever so slightly narrower, it'll most likely tend to further minimise both the tendency to wear the rear tire out in the middle of the tread and also to lessen any propensity of the 'big wide rear tire' might have in causing your Spyder/Ryker to hydroplane on a wet enough road! It won't completely remove the possibility of either, but it'll certainly reduce those tendency's!
Oh, and the marginal sidewall height increase due to the 60 profile instead of the 50 profile will help to reduce the 'built in' speedo over-read; so it'll probably be showing you a speed that's a bit closer to your true speed instead of telling you you're doing 60 when you're more likely to be doing closer to 54.... and that same correction will also help correct your odometer & trip meter readings too!! Sure, the factory 'built in' error on both isn't going to be any greater that 10% over, but it's still an error that the slightly larger rolling diameter tire will reduce, so why wouldn't you if it's that easy and by a simple choice like that, you can?!?
Enjoy!
2013 RT Ltd Pearl White
Ryde More, Worry Less!
