Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
  1. #26
    Jul 2020
    Syracuse NY
    I am new to the Spyder Community and have a 2020 RTL Marsala Red. I’m trying to figure out how to get my iphone from automatically opening the music and playing? I want to be able to turn the music off and just listen to the gps directions from my phone when its connected by blue tooth. When you turn the volume off for the music on the bike it turns all sound off??? What am I doing wrong??
    Thanks for your help! Ride Safe!
  2. #27
    Active Member anthony422's Avatar
    Aug 2013
    Mahopac,NY
    Connect does have a mind of its own I will say takes a while to pair
  3. #28
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by 2020RTLimitedDRM View Post
    If you pause/mute the BT music. Not lowering the volume. Starting from the correct volume level. Hold the the joystick down until the the screen shows pause. It is the short double bar symbol. The music should be paused, but the GPS audio should come through just fine.
    If that does not work. Just turn the audio player off. That is done from the phone. Not the Spyder.
    PS Since you have a 2020. You should be able to pause from the audio controls as well as from the joystick.
  4. #29
    Jul 2020
    Syracuse NY
    Thanks I’ll try that!! I can pause the music from the phone, but once it locks with the connect it starts playing again.
  5. #30
    Aug 2013
    SF Bay Area
    IN the volume screen you can hold the joystick down and the music will stop. As for it automatically playing, haven't had that problem as I have to switch to BRP C then to the music to get it to play. Whether FM or other music, FM starts when the system finishes booting, Bluetooth music has to be started, it won't get going automatically.
    2021 F3 Ltd , Magna Red
  6. #31
    Jul 2020
    Syracuse NY
    Well I have tried all suggestions. When putting the sound to pause (II) it pauses all sound, even the gps directions. When sound is on and the volume is at its lowest, the GPS will lower the music sound and say the directions. I even deleted the app of the phone completely and it is the same. So connecting to the bike is really only good for charging the phone while riding which is good. Everything plays through Bluetooth anyways. As far as the BRP connect app using your maps on an iphone, it doesn’t show the route anyways!! And I’m not paying for a mapping software that is quirky to begin with. Thanks everyone for your help! Hopefully BRP connect will have some updates that will improve their app.
    On another note! How do I add a picture of my bike to my screen name??
  7. #32
    ....... On another note! How do I add a picture of my bike to my screen name??
    The 'Quick'n Easy' way?? - Click on 'Notifications' up the top right of your screen, then 'Inbox' in the drop down list. Once that screen paints up, check out the Left Hand column & go down to where it says 'My Settings'. In that section there's a bunch of red links, & one of them should be a link labelled 'Edit Profile Picture' - hit that, and then choose whichever Option you prefer in the field that says 'Custom Profile Picture', and load a pic up before saving. You might want to check which way your chosen pic is going to display before locking it in, because the Forum software uses the Top Left corner of any pics as its 'anchor point', so if you took the pic on your phone in 'profile' orientation (most phones use the Top Right corner as their anchor in profile mode) instead of turning it anti-clockwise & into landscape mode, your pic might come out sideways.... or upside down! And you might need to reduce the size/definition of your pic too, just so it'll fit. But with any luck, following that lot should work, drop me a PM if it doesn't.
  8. #33
    Jul 2020
    Syracuse NY
    Thanks!!! Done!
  9. #34
    Jul 2020
    Syracuse NY
    Test Message
    Ride Safe!
  10. #35
    Test Message
    Glad it worked for you.
    That's got your Profile pic working, and showing as your Sig Line pic; so what about adding an Avatar pic, a different one maybe??
    You can do that in the same place, just pick the appropriate red link.
  11. #36
    Aug 2020
    Florida
    Default Intercom
    2020 RTL
    Been reading a lot but can not seem to figure this question out —-
    So will wireless earbuds with built in mics work with BRP Connect as an intercom with driver and passenger.
    Or
    Do I have to buy something like a Cardo or a Sena?
    Charlie
    (My first post on this site)
  12. #37
    Jul 2011
    Quote Originally Posted by charlesl View Post
    2020 RTL
    Or
    Charlie
    I assume it will pair. I would think you should just try it and find out. Don't know how well it would work with the helmet. Wind noise and location of the microphone. Again that may need to be tried. Let us know how well it works.
  13. #38
    Jul 2011
    Well you got me curious. So I went out and tried it. The music player started automatically like normal and I like it that way. But for testing. I paused the music player from the handlebar controls. Tried the Waze GPS app. The sound cam through just fine. Tried Google maps driving app and no sound. Then I tried Genius Maps and the sound again came through just fine. I tried several more apps. All of them worked and the music app stayed paused.
    You did not say what GPS app you where using. If it was google maps driving app that could be your problem.
  14. #39
    Jul 2011
    You do not say what music app you are using. If it is Google Play Music app. then go into the settings and turn off the setting in the picture below. If you are using another app. Look for a similar setting.
  15. #40
    Jul 2020
    Syracuse NY
    The Apple Maps from the iPhone XS. I will try again. Through the blue tooth connection I can get the map directions with the Apple Maps and google maps. I can’t turn off the music player on my phone. It’s an apple thing. But pausing the sound on the bike for some reason pauses all sound from my phone.��
    Ride Safe!
  16. #41
    Jul 2020
    Syracuse NY
    Ok I just tried the music and gps on the Spyder. I spoke with apple support and they said to contact BRP as it sounded to them that it is a firmware issue! So I turned the key on, and plugged my phone in. After loading everything the music started playing. I used the apple mapping and selected a point to go to. The music muted and the map announcement came through. I used the joy stick and moved the sound to pause “II” and no sound came through at all. I tried to video from my phone but the unmuting kept turning off the camera sooo... I got my gopro out and videoed the best I could. I will need to make a movie so its not as large as a file. Can the video be posted on this site? With the phone unplugged from the Spyder the music will continue to play along with the gps directions, if the sound isn’t paused. So it is something in the firmware/software on the bike as it does not use the cable except for charging and locking out the phone so you can’t use it!
    Ride Safe!
  17. #42
    Jul 2011
    All audio and telephony functions from your phone to the dash is BT and has nothing to do with whether the usb cable is plugged in or not. If you wish to see your compatible apps on the Spyders screen then the usb cable has to be plugged in. There is not enough bandwidth on BT for both audio and video. I never plug my phone in and it's mounted on my handlebars. Also have installed a USB power plug there if I want to charge my phone. I use the phone screen for the gps.
    The issue you are having must have to do with a setting with your iphone. As mentioned in a previous post. Flamewingers iphone does not auto play.
  18. #43
    Apr 2021
    Florida
    so i have this same issue. if BT is on my phone apple music autostarts. if i mute or pause music, no map audio. i just want to hear apple map gps audio - no music.
    i don't see any settings on the spyder that might help and i've searched iphone forums and tried their suggestions.
    it's become an obsession for me!
    any ideas?
    thanks, randy
    2019 F3Ltd
  19. #44
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    ..... There's also a BRP Connect group on facebook.
    I'm having difficulty getting my Android Phone to bluetooth with my new to me used 2020 RT LTD. Even BRP Tech Service gave up. The Facebook Group is Great if you have BRP GO issues. But since sync'ing the phone to the bike IS NOT, I got asked what am I doing on their Facebook Page. Friendly helpful folks; NOT!!
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
  20. #45
    Jun 2021
    OR
    Since it is used, make sure you first delete the current paired devices. I believe you can only have two phones at a time so the slots may have been already used from the last owner.
    2021 Syder RT Limited
  21. #46
    Harrington, Australia
    Quote Originally Posted by obiwanbill View Post
    Hahaha…….the vast majority of members of that BRP Go site are VERY helpful, Bill……..I reckon I could have a pretty good guess at who the agro responder was
    HeliBars Handlebars
    Kenda Kanine rear.
  22. #47
    Does this help, or have you been through it all? BRP GO FAQs on the Ski-Doo site. It's the answer to "My Smartphone device won't connect..." https://www.ski-doo.com/us/en/ski-do...rp-go/faq.html
    - Ensure your device is not locked (i.e. you have your apps in front of you, no need for a PIN, password or any other unlock procedures) and that BRP GO! is open on your phone when connecting it to the vehicle.
    - Make sure the smartphone is connected to the USB at the front of the vehicle and that you use a good quality USB cable, i.e. the one usually provided by your phone's manufacturer.
    - If you have an Android device, make sure that you have allowed BRP GO! to display over other apps (appear on top of other apps) in phone settings.
    - If this does not work, validate if your device is compatible with BRP GO!. The BRP GO! app only supports specific phone models and does not support tablets or iPods. This means that a connection with non-supported phones, iPads or iPods might work but is not guaranteed to function properly.
    Have you deleted all the users as shardt suggests? Is there a way to do a reset to factory defaults? If so, do that. Also double check that your phone is on the compatible list.
    Also consider uninstalling BRP GO! and make sure BRP Connect app isn't found on your phone. Then install the APK to your phone not using the Play Store. Info and latest version is here. https://m.apkpure.com/brp-go/com.brp.brpgo You may need to do a factory reset of your phone. Just be sure to save everything to Google cloud first. When it asks to reinstall apps uncheck BRP GO.
    Another thing, if you haven't already, is to do a reset of your Spyder. BRP Connect is the technology that communicates with your phone and is a part of the cluster. It may be mucked up.
