Results 1 to 25 of 25
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default Checking oil quantity
    I drive the miles, let idle for 10 minutes to check the oil level. The problem is that the oil is so clean and the dipstick color is such that I can't see where the level is (I know that there is oil in there). Any suggestions?
    Jul 2014
    Mint Hill, NC
    When you pull out the dipstick immediately lay it on a piece of paper towel and you'll be able to see the oil level in relation to the Min & Max marks. It will be easier after an oil change or two.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    May 2019
    Palm Bay, Florida
    Thanks Jay. Will give it a try.
    Feb 2020
    Oceanside, Ca.
    I drilled a tiny hole in the stick in the middle of the full and add markers.
    Works great.
    Dec 2019
    Land of Lincoln
    A little John Deere hydraulic oil dye will tint it and make it easy to see.
    KYNETX dye on Amazon... https://www.amazon.com/Kynetx-Concen...5869643&sr=8-8
    Motul 7100 is blood red, easy to see.
    Motul 300V is nuclear waste green.
    The paper towel trick works too.
    Quote Originally Posted by Baron14y View Post
    one - two minutes is plenty of time for an accurate measure ..... and the suggestions given above are helpful ..... Mike
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    Why do you need to check the oil?
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Aug 2007
    Greeneville, TN
    I agree. Idling for 10 minutes is hard on any engine. And unnecessary.
    May 2019
    Palm Bay, Florida
    I agree but, that is the instruction on pg 123 of the owners manual. Why, I do not have a clue.
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Dudley View Post
    I guess I'm just old fashioned and like to know that the internal combustion engine I am operating has lubricant in it so that it doesn't seize up. Have done the same thing with jet engines as well as ic engines in many airplanes.-
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Spyderup View Post
    Works great.
    How does that help me see the oil level?
    Mar 2015
    forrest above Reno, Nv
    I've used the paper towel trick when checking the oil level ( although the 1330 motor uses no oil) I filed a v-notch at the midpoint of the oil reading area but it didn't help. Bob Denman was the first I saw who suggested the paper towel trick.
    Lew L
    2014 RTS , Circuit Yellow
    Apr 2019
    Florida Swamp
    If you can't see where the oil is on the dipstick any other way, you can always use the baby powder leak finder trick. Sprinkle baby powder on the dipstick and blow on it. Where there was oil, the powder will stick.
    2019 F3-S , Black & Silver
    Quote Originally Posted by Gwolf View Post
    Orrrrrrrrrrrrrrrrrr use common flour ...... lots less expensive ............. But it's a good way to tell ..... make SURE you clean the stick ...... Mike
    Feb 2012
    Spring City,Utah
    The oil will coat the hole. If there is oil in hole you are ok, if not add a little until it does. AND since you are using a towel to wipe off the stick anyway you can also do the towel trick. 1330 do not use oil but it is always a good thing to check, if it is low you will know there is something wrong with your engine cus it is now using oil.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2019
    southwest oHIo
    Quote Originally Posted by Lew L View Post
    ... ( although the 1330 motor uses no oil) ...
    ... 1330 do not use oil ...
    OK, detour here. Two guys are now saying their 1330s do not use oil.
    What DO you put in the engine for lubrication?
    Apr 2019
    Florida Swamp
    Quote Originally Posted by Steve W. View Post
    You put oil in the engine for lubrication, but then you get the same amount back out of it that you put in it, so it didn't use any.
    I've been on this site since forever .... the V-twin used an abnormal amount of oil - imho ...... the 1330 doesn't use any ...... Mike
    Active Member Bling Bling's Avatar
    May 2010
    Arizona/Colorado
    Here's an old thread that might help you out.
    https://www.spyderlovers.com/forums/...ngined-Spyders
    2020 Petrol Metallic RT-Limited Dark Edition
    2014 Silver Platinum Satin RT-Limited SE6 Project Road Warrior Edition (previous ride)
    2009 Red SM5 (Previous Ride)
    Retired MSgt ('89-'13) U.S. Air Force - A-10 Crew Chief
    Dec 2019
    Land of Lincoln
    One reason the twin used oil because folks followed BRP's recommendation of a 40 weight oil, and used the BRP 5w40. It would shear to 20 weight pretty quickly, and be consumed in various manners by the engine (air box, past rings). Wide spreads like that and shared sumps and you'll always see shear.
    There were a few of us that realized the same engine in the Aprilia line has a 15w50 specification. I can say from experience, running a 50 weight in the VTwin worked fine, it was still a 40 weight at 3000 plus miles, and didn't disappear.
    One of the best runs I had was with conventional Havoline 20w50. Yep, the 1.39 on sale stuff.
    May 2019
    Palm Bay, Florida
    Finally got around to checking the oil with the paper towel. Worked great. Thanks Jay.
    Mar 2015
    Question Wd-40
    I use Shell Rotella oil for lubrication on my . It has a 1330 motor and Consumes No Oil. Isn't the English language wonderful. ( sarcasm notice!!!!)
    Lew L
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    BRP recommends running the engine for 10 min. to recheck oil level after finding it below the min mark and adding oil.
    From BRP manual for 2014 RT
    Oil Level under MIN Mark Adjustment:
    1. Add approximately 500 ml (17 U.S. oz) of recommended oil.
    NOTE: The oil quantity between MIN and MAX marks is 500 ml (17 U.S. oz).
    2. Restart the engine and let it idle for 10 minutes
    3. Stop the engine.
    NOTE: Engine oil level verification must be performed within 2 minutes after engine stop.
    4. Recheck oil level.
    5. Repeat the above steps until oil level reaches the dipstick between the lower and upper marks. Do not overfill.
    When in doubt, follow the manual. BRP uses the manual to CYA, you should be good if you do.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by LongIsland View Post
    3. Stop the engine.
    Yes, you are both correct about the information in the manual. But the question is, are the instructions giving you good information. I know there are those who feel the manufacturer is never wrong. And, in the case of BajaRon's products, this does hold true, of course.
    But the fact is, no one is right all of the time. Including the one who produces the product.
    If it were necessary to idle for 10 minutes to get a good reading, then that would be good information. But it is not. What they are talking about in the manual instructions sighted is adding oil to the system and then checking the level. The 10 minutes is recommended to bring the system back into balance. Still, way overkill, in my opinion.
    But if you do what most recommend. Check oil level while out on a ride right after stopping, (at a gas station, restaurant, etc., on flat, level ground). Or at the end of a ride at home or at the hotel. It is a much better way to go. I like gas stations when checking on the road because you know the ground is level. Then you only need 30 to 60 seconds of idling before shut-off. Then check the level.
    Idling for long periods of time is detrimental to engine components. Can increase cylinder wear and wastes a lot more fuel than you realize.
    Bottom line is, that it just isn't necessary. Try checking the oil level using both methods. You'll find that both will give you the exact same reading. And one will do it with zero collateral issues.
