BRP - Safety Campaign Bulletin #2020-5 NOTICE
THE HEADING SAYS RECALL, BUT IT IS A SAFETY CAMPAIGN BULLETIN ( sorry for the confusion)
BRP has determined that the 2020 RT series has a problem in that if you make a sudden hard pressing of your brake pedal, the bracket may break, they need to supplement the brake pedal with a bracket.
Call your dealer with the Safety Campaign Bulletin # 2020-5 so he can order you a bracket
THIS IS NOT A APRIL FOOLS JOKE, This bulletin was just issued today.
I tried to upload the Bulletin but this site will not allow it because the item is too large.
Cruzr Joe
Reason: Title - Bulletin not Recall
Brake pedal breaking appart that is kind of a critical item? Isn't it?
I guess they have not worked out all the technical issues on the new 2020 models before they put them for sale!
First it was all the panels not fitting correctly and being tied with zip ties, now this. Give me a brake or is it a break?
Cruzr Joe
Hi Joe,
Do you have a link for this bulletin?
My dealer just called me. They said to not ride it. Either they would come pick it up or I could trailer it to them. Also, they are going to the the 2 pieces between the saddle bags and the frame to correct the fit-n-finish.
Originally Posted by Purple Guy
Hi Joe,
From a post in the RT-Touring subforum. https://www.spyderlovers.com/forums/...recall-already
https://can-am.brp.com/on-road/us/en...-CZZB9Cy2u-ph0
2014 Copper RTS
