2016 F3-T handlebars question
So I moved my brake and peg to the #5 position.
My handlebars are set for the #4 position. I would like to swap them out so I can get #5 handlebars. But I see different types when looking around for just the plain black ones.
Does anyone know where I can go to get a good set up handlebars for the #5 position?
Not sure what you mean by #5 position as the F3's use differant style bars. If you are looking to get them closer to you they have the short reach bars for that.
Another option that is fully adjustable would be the HeliBars for the F3.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
I have the short reach handle bars that came off of my 2016 F3T that I am not going to keep on my 2020
RTL if you are looking to get the grips closer to you, I will be posting them on here for sale very soon.
Toby
2020 RTL
I am looking for the handles to be farther from me. The dealer said my current handlebars are in the #4 of the ufit system.
I think it is the Drag bar position E that I need to get.But the pictures show some sort of brake handle on it?
https://can-am.brp.com/on-road/us/en...f3-models.html
It's just the center of the handlebars you change your existing throttle and controls bolt on the end of the bars Handlebar0.jpg
You need the position E drag bars. I have them on my F3s. They are the furthest away you can get. I have a pic comparing the stock position 3 I believe to the drag bars.
That looks to be exactly what I am wanting. Thank you for the clarification.
That's a clutch lever on the left side on an SM6 manual shift. Adding a brake lever on the right side is $1200 after market.
http://www.industrialspecialty.com/I...andbrakesystem
Anyone have some info on how to swap out my current handlebar for the straight drag handlebars?
Do you have Risers for when you installed those drag bars?
The riser you see there comes with the drag bars. If the drag bars were installed where the stock bars are they would hit the tank while turning.
I just swapped out my bars on my 2018 F3L. Extremely easy to do. I went with the HeliBars. They have so many adjustments that the will work for just about everyone.
BKMNI
RWP!
2018 F3 Limited
Intense Red Pearl
2015 Harley Davidson
FLRT "Freewheeler"
Vivid Black
