Results 1 to 6 of 6
    Mar 2020
    Union,wa.
    Spyder Will Sena Freewire work for CB & Radio on 2015 RT?
    Recently aquired a SENA FREEWIRE for a Goldwing to go with our sena S20 bluetooth headset. Will this freewire work on our 2015 RTL for our CB and radio.
    Nov 2018
    Claremore, Ok.
    Call Sena customer support.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Linden, CA
    NO that unit is made for the GoldWing & the Harley only
    Linden, CA
    Quote Originally Posted by bsmason View Post
    Give me a call I will help you with information regarding bluetooth items for your Spyder
    Dave
    motorcycledave@mac.com
    209-887-3283
    Idaho
    As Dave says, Sena makes them for the Harley and GW only. The GW headset is 5 wire while Harley and Spyder is 6 wire. It might be possible to make a short adapter cable to swap the pinouts on the Harley cable to match the Spyder pinouts. I've thought about trying it but have not felt compelled enough to move to Bluetooth to want to tackle it. If you're handy with basic electronics and wiring I can explain what needs to be done. Harley and Spyder headsets use the same power and signal wires in their headsets but the arrangement in the connector is different.
    2014 Copper RTS
    Idaho
    Quote Originally Posted by Revalden View Post
    Sena has no interest in dealing with the Can Am CB radio connections. I contacted them once and got a strong brush off.
    2014 Copper RTS
