Results 1 to 8 of 8
    Feb 2014
    Orland Park, IL
    Default 2020 Heated Comfort Seat
    Question about the heated comfort seat for the 2020 RT...do you sit further back in it than the stock heated seat? (Does it give more leg room?)
    I had the comfort seat on my 2015 RT and it definitely sat 2" further back, giving more leg stretch. I just want to make sure that's true of the 2020 seat. Also, does it require a different driver backrest than the stock heated seat backrest.
    May 2013
    Indiana
    From what has been published, The 2020 stock seat is already is set back for both the rider(2") and passenger(1"). No comparison to the 2014-2019 seats. The 2020 comfort seat has a different stitching pattern and has more padding(gel???). It's almost a $1,000 option. Don't know what the aftermarket will come up with.
    I'm considering that option also.
    Mike
    2021 Marsala Red Metallic RT Limited
    Jan 2020
    New York
    We have the Comfort seat and it is the same as the stock seat from a sitting position. Just more comfortable with the memory foam!
    2020 RT Limited , ASPHALT GREY METALLIC - DARK EDITION
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    Quote Originally Posted by AdmiralS View Post
    If that’s the case I would save the $1,000 and go to a custom seat that is made for your butt. Laam Custom Seats would be my choice and would cost a whole lot less than $1,000.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    Ok, so I went to the Build section for the RT and the stock seat on a limited comes with this:
    SEATS
    HEATED DRIVER SEAT
    219401044
    With an exterior identical in every way to our quality stock seat our Heated Driver’s Seat comes with the added perk of integrated heating that’s designed to keep you warm and comfortable when temperatures start to dip. Stock equipment on the limited edition model.
    With comfort seat, this:
    COMFORT SEAT
    219400971
    $ 699.99
    Extra padding in all the right places in addition to a memory foam layer gives us every reason to call it our Comfort Seat. Smartly styled, its elevated passenger seat gives anyone coming along for the ride a scenic way to enjoy the open road.
    And for heated comfort, which is what I got, this:
    HEATED COMFORT SEAT
    219400972
    $ 909.99
    All the features of the much-loved Comfort Seat with integrated heating. Unit complete with individual dual-intensity driver and passenger controls for customized warmth when the weather’s cool but the ride is still hot.
    So for $210 more you get individualized heat for driver and passenger. That seemed worth it to me. in addition to the Extra padding in all the right places in addition to a memory foam layer gives us every reason to call it our Comfort Seat.
    and if you receive a discount when ordering so it's really only $800 more than the stock.
    Feb 2014
    Orland Park, IL
    Quote Originally Posted by TicketBait View Post
    SEATS
    HEATED DRIVER SEAT
    219401044
    COMFORT SEAT
    219400971
    $ 699.99
    HEATED COMFORT SEAT
    219400972
    $ 909.99
    When it says "all the features of our much-loved comfort seat with integrated heating" The older comfort seats sat back 2" from the stock seats, so does that mean this one does too? By the way, the stock heated seats on the 2020 RT Ltd has heat in both the driver seat and passenger seat with separate controls.
    Feb 2014
    Orland Park, IL
    As an FYI, Here's what I received from BRP re: the 2020 Comfort Seat.
    Good Afternoon
    Thank you for reaching out to BRP! I'd be more than happy to help you.
    In response to your email, the comfort seat has the same demensions as the stock seat, however it has additional padding in some spots. It will not sit the driver further back.
    Once again thank you for contacting BRP.
    If you have any further questions, please do not hesitate to click reply on this email or contact us at 1-888-272-9222. My Colleagues and I are always happy to help.
    Yours in adventure,
    Veronica,
    Customer Service Representative.
    Looks like the mystery is solved. This go around...same dimensions as the OEM, but more padding in all the right places, per BRP.
    I am a fan of the BRP comfort seats. I have put four of them on four different Spyders. They have always worked well for ME.
    My most recent (2019 F3L). Non-heated...Cannonball Cross Country.
    Cannot speak specifically to 2020, but there are at least 28 out there with potential beta testers.
