Results 1 to 11 of 11
    Active Member TheCajun1957's Avatar
    Kilgore Tx.
    Default 2018 F3L: Aux Plug for dash
    Is there a separate volume control for the Aux plug? I plugged my GPS wiring harness into the aux plug, turned all of its volume controls to 100% and the dash volume control 100% and I can just barely hear the GPS unit on the speakers. What am I missing?
    2018 White F3 Limited
    Feb 2019
    Portland, Oregon
    Maybe the speakers in the GPS are loud enough to hear? Mine is and I have a quiet helmet.
    Kilgore Tx.
    The GPS unit is a zumo 665, it has xm radio in it, that's why I am trying to get gps hooked up the speakers.
    Sep 2009
    La Valle, WI
    Did you turn the volume up on the bikes joy stick. Push up.
    2018 F3 Limited , Oxford Blue
    Kilgore Tx.
    Yes Sir, all the way up.
    Oct 2013
    rome new york
    If i use aux plug volume sucks. If i use bluetooth with my phone works great. I use google maps from my phone
    Sep 2009
    La Valle, WI
    Quote Originally Posted by TheCajun1957 View Post
    I do not use AUX but I know Volume on the bike was low before the 20.8 update came out. Does your bike have that update.
    Kilgore Tx.
    Yes I do have 20.8. Hope they come out soon with an software update for the 18 and 19s.
    Sep 2009
    La Valle, WI
    There is an update to 30. something. it is on the new RTL and F3L I confirmed this when I was at the dealer a few weeks ago. I scrolled thru settings to about section on both models and it was there. Do no know what the update will do.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    lamonster has a video about how they got a zumo XT working with music but doesnt mention the xm. Im trying to get my 665 to show up on my 2014 RT and bought their entertainment harness but it appears its for their add on XM radio not to get XM on a Garmin.
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
    Kilgore Tx.
    AbNormy, Try using the 665 only, blue tooth the phone to the 665 and then add your helmet. There are separate connections in the 665 menu for them. If you just want the 665 output on the spyders speakers, you might be able to use the adaptor plug (looks like headphone plug)that fits the connection in the trunk. Run an extension from the rear to the 665 aux output, then select aux input on the spyder dash screen. Make sure ALL volumes are 100%. You may have the same problem I am having, very low volume as the aux output of the 665 is very weak.
