Results 1 to 12 of 12
    Active Member upsdoctor's Avatar
    Mar 2010
    Derry, NH
    Default Fobo 2 Issues - Valve Stems and BRP Connect
    First issue... I bought the FOBO 2 for Trike and installed it using the factory rubber valve stems. After reading a few posts about how a TPMS sensor could rip the rubber valve stems off, I decided to have the FOBO chrome stems installed (came with the kit). Well as it turns out the FOBO stems will not work with the Can-Am wheels, they are too short and now I cannot reinstall the sensors. Has anyone else run into this issue? If so what specific valve stems did you use to correct it?
    Second issue... It is documented in the forums that FOBO 2 does not work with BRP Connect. Does anyone have an update from Can-Am or FOBO regarding this issue? Has anyone gone back to the original FOBO software using the FOBO 2 sensors?
    It is maddening to purchase such a simple product and have to spend time and money to un-****-it. I should have went with the Garmin TPMS
    Thanks in advance, Bob
    Bob H - Derry, NH
    2020 Spyder RT Limited - Petrol Metallic Blue
    2010 RT622 Trailer and BRP Hitch
    BRP Vented Touring Windshield, BRP Backrest
    Garmin 590 with BRP Mount
    Fobo TPMS for Spyder and Trailer
    Lidlox, Blue Sea Fuse Box for power distribution
    Ram Ball Mounts for Radar Detector, Cup Holder and Phone Holder
    Sena 20S / SL2 Headsets, Foam Grip Covers, Belt Tensioner
    BAJA Ron Sway Bar and Shock Adjusters, Heli Bars
    Active Member kissfan's Avatar
    May 2019
    Brooker, FL
    I dropped a line to FOBO last week about the BPR Connect integration. FOBO has submitted everything to BRP, and it's now in BRP's hands.
    So... I submitted a "how's it coming" to BRP, and I'm still waiting for their reply.
    If it's anything like other BRP bug fixes/mods... it'll be awhile.
    My vice is passion for KISS.
    Oh, and food.
    Current ride: 2019 Spyder RT-L in Phoenix Orange.
    2019 RT-L , Phoenix Metallic Orange
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I’m having the same issues. I can’t get the new sensors to work with the old software, although the new software will work with the old sensors. I asked FOBO when it make FOBO 2 compatible with BRP Connect, and this is what I got...
    “ We are still working with them to make it available for BRP Connect. At this stage, we have released few versions of App for their side to test of the compatibility.”
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Clinton, MS
    FOBO works fine with stock rubber valve stems. My plan is to replace the stems every tire change to prevent any problems. Not sure there would be any anyway as short as they are.
    FOBO Bike 2 app released another upgrade today. As they have done on other recent updates under What's Pending: - BRP Connect Integration.
    May 2019
    Brooker, FL
    Received an email from BRP today (yeah, I know) and they said FOBO2 should work, and that I might need to get the latest firmware flashed on the RT... and to contact my dealer.
    Anyone know what the current level of firmware is for a 2019RT? IIRC, I'm sitting at 20.8, which I thought was the latest.
    Last edited by kissfan; 04-01-2020 at 12:50 PM. Reason: Fixed firmware revision level
    Oh, and food.
    Mar 2010
    Derry, NH
    Not positive, but it looks like my 2020 RT has version 030.70.
    Bob H - Derry, NH
    Clinton, MS
    Quote Originally Posted by kissfan View Post
    20.8 is supposed to be the latest for 2018 - 2019.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    I completely disagree with the "replace valve stem" recommendations and here's why.
    I just upgraded my original FOBO with the newer version. There was nothing wrong with the originals, but wanted the upgradable firmware and better battery life.
    I used the original stems on the FOBO.
    The first thing I did after removing the originals was to compare them to the FOBO 2.
    The Fobo 2 is smaller AND lighter then the originals .
    Since FOBO did not make a "recommendation" to replace the stems for the originals and there would be less effects of centrifugal force on the smaller, the recommendation given for FOBO 2 is at best a CYA and NOT supported by science.
    Naturally this is just an IMHO, do what you must, but it makes no sense to replace with metal stems.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    May 2019
    Brooker, FL
    I called BRP last week about Connect and AccuWeather.
    They stated "we're aware of AccuWeather and are working on it. But we didn't know about FOBO2."
    BRP should completely outsource their entire IT group instead of just the Connect developers (Bosch?).
    Edit to add: I've only called them twice before and sent 3-5 emails on FOBO2. *sigh*
    Oh, and food.
    Aug 2013
    SF Bay Area
    The shorter stems are for F3's as they won't fit on the OEM stems. For the RT's, just install them to the OEM stems. Have had them for over 2 years and no problems. It's been known that FOBO ii is ready for BRP C but it's been over a year and still no updates. The 2020's have a different dash version due to the different buttons. Still waiting for an update for the 2018/19's. I've emailed them for months and all I get is "We're working on it" or "its already done" They just don't know what they're doing! Sad.
    2021 F3 Ltd , Magna Red
    Bossier LoUiSiAna
    *sigh*
    but that would mess with “see your dealer” CYA line they depend on.
    May 2019
    Brooker, FL
    Bwahahahahahaha.....
    Oh, and food.
