Results 1 to 3 of 3
    Mar 2020
    ITALIA
    Post Rt spyder limited 2019 light switch
    Greetings to the entire group, i am italian.
    Different and high beam lights switch.
    When switching from different light to high beam, the different light turns off.
    This is normal
    can anyone help me.
    Thanks
    leonardo
    Dec 2013
    Welcome to the Forum proper & posting, Leonardo. I think that what you are saying/asking is correct!
    Here in Australia, our RT's and F3's have similar lighting arrangements to what you have over there in Europe/Italy; and both your and our HIGH beam lights are where the North American Spyders have both their High & Low beams, only theirs are powered by one single globe per light assy with a shutter arrangement to give the different beam patterns & light outputs. Our LOW BEAM lights are the same as the Euro spec lights in that they are down where the North American FOG lights are. And when we switch our lights from LOW beam to HIGH beam, the LOW beam lights go OUT, & vice versa!! So if that's what yours is doing, then that is standard and correct for all Euro and Australasian RT & F3 Spyders!
    However, it's not very hard to modify the wiring & add a relay so that your Low beam lights stay on ALL the time (see Pogo 4 Eyes) and there are also some Australian &/or New Zealand Spyders/F3's that have fitted dual filament Hi/low beam globes to the Upper lighting positions, with the wiring modified to work both Hi & Lo beams from up there, with a set of extra lights installed on a separately switched circuit to power another set of globes down in the former Low or N/American Fog position. Depending upon what globe size &/or beam pattern you choose for those lower lights, you can set them up as Fog lights, Driving or Spot Lights, or Daytime Running Lights.
    All the 1330 Spyders have enough electrical power from their alternators to run an extra set of lights like that, but you need to be a little careful if you try to do that on a 998 V-Twin powered Spyder, cos the twins with their magneto don't have quite the same electric power output to spare!
    Over to you, & Good Luck! Stay safe & healthy, and enjoy the Miles of Smiles your Spyder can bring!
    Cheers
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    hi leonardo
    yes it is normal
    you can change this though
    contact here for pogo 4 eyes......http://www.pogotronics.com/?tag=four-eyes-high-beam
    russ
    pres ride
    2014 RT-S
    bike is WIP
    bike has endured elect spike (was jump started incorrectly)
    still a WIP but bike is now running and registered....swapped out 5 modules mostly sourced from Canadian wrecker
