Results 1 to 5 of 5
    Nov 2019
    Alberta, Canada
    Default pulling a aftermarket cargo trailer - is there a wiring adaptor?
    is there a wiring adapter harness to go to 4 pin from can am RTL bike
    Last edited by Peter Aawen; 03-26-2020 at 02:18 PM. Reason: This is a "How do I?" question not a "How to do:" description
    indpls in
    yes check out value accesories
    Active Member funon3's Avatar
    Mar 2010
    Indianapolis, IN
    You can also check out Lamonster Garage. I got a 4 square to 4 flat adapter from him.
    My new ride is a 2017 F3-L: BRP drivers backrest, F4 21" tinted shield w/vent, Lamonster fog lights, TRCLED cyclops light, red/black carbon fiber tank protector and dash kit from Wrap-My-Spyder, FOBO tire pressure monitors and more farkles to come.
    Jul 2011
    Mitchell, Ontario, Canada
    You do not say what the connector is on the trailer.
    If it is a flat 4. You can cut it in half. Fold it over. Tape the 2 halves together. Never done this myself but has been posted several times as working. You can also make your own adapter. Order a Hopkins square four trailer plug online and a flat 4. Just connect the same color wires together.
    If it is a flat 5 or round connector. The answer gets far more complicated. So if that is the case. Just let us know what you have.
    Nov 2018
    Waynesboro, PA
    My Spyder
    2012 RTL , Brown
