Results 1 to 10 of 10
    Active Member sledman's Avatar
    Nov 2016
    Default Balancing Vredestein Quatrac 5
    I'm putting these tires on the front end of my Spyder. They have no balancing dots on the sidewalls, but there is a blue dot inside on the tread portion. Can anyone here tell me if this dot is for balancing?
    Thanks!
    Jun 2010
    Las Vegas
    This article should shed some light on tire dots. https://www.tirebusiness.com/article...erve-a-purpose
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2015
    forrest above Reno, Nv
    Thanks Ann, Always learn something new on this forum. "Red dot"--- thought it's a sighting device for firearms------ I'd rather have a laser.
    Lew L
    2014 RTS , Circuit Yellow
    USA
    Mr Lew,
    I took my front tires and rims to a car tire place with a road force balancer. That is a great machine. Adjusts the high spot to work with the out of balance condition to give you a tire that runs true with the minimum amount of weight. Some places are a little uptight about putting car tires on a motorcycle rim, so I tell them it's for a trailer.
    h0gr1der
    Mar 2015
    Thumbs up No balancing weights-----
    Quote Originally Posted by h0gr1der View Post
    Mr Lew,
    Thanks h0g,
    In a similar vein----- When I had the rear tire (Altimax)installed on my RT, the tech rotated it on the rim to get a balance with NO weights. Wish they could have done that with the new Vredesteins fronts but they took very little balancing weights.
    Lew L
    Apr 2012
    Florida
    Mr Lew,
    It's not a motorcycle rim. Says so on the inside. Tom
    2020 Petrol Blue Metallic RTL
    Quote Originally Posted by Lew L View Post
    Thanks h0g,
    Lew L
    just a footnote ..... I didn't even bother to balance my last 5 rear tires .... it's just not necessary .... jmho .... Mike
    Feb 2020
    N. Wilkesboro, NC
    Lew L
    Had both. Much prefer a red dot, especially once you get used to it.
    Aug 2019
    Stoughton, WI
    All three of my OEM tires/wheels had a crap load of weights stuck on from the factory. All three wheels balanced out nicely with one weight each with the car tires installed (Vredestein Q5 fronts/Cooper CS5 Ultra rear). After that, I put appropriate amounts of Ride-On sealant/balancer in each tire. Rides/tracks perfectly...
    2022 RT Sea To Sky
    Nov 2016
    Thank you Ann for the link! And thanks to all for your input.
