Results 1 to 7 of 7
    May 2019
    Mt. Juliet, TN
    Default Pass Footpeg -- how do I tighten them?
    2020 F3-T passenger footpeg is loose and will not stay in the raised/non-use position. I tried the hex head bolt but cannot budge it. Not sure what to do if I do get it loosened other than add another washer. Any suggestions?
    Last edited by Peter Aawen; 03-26-2020 at 12:30 PM. Reason: This is a "How do I?" question not a "How to do:" description
    Mar 2013
    Marion, Arkansas
    I know on my 2017 F3 limited the passenger floor boards will also not stay upright out of the way. When the floorboard is raised it will rub the panel and if it would stay upright it would scratch the panel. So I just leave it in the down position.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jun 2010
    Las Vegas
    Rocket is correct.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2012
    North Las Vegas, NV
    On our 2016 I took the pegs off and lubricated the bolt and that fixed it.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Aug 2019
    Stoughton, WI
    My right one is the same way on my 2019 F3-S. I just put a dab of black silicone in the gap to hold it up. If I need service, I'll have it fixed under warranty.
    2022 RT Sea To Sky
    May 2019
    Mt. Juliet, TN
    Highwayman, Did you have difficulty getting the bolts loosened. How did you remove them is difficult?
    I can't loosen mine w/o more torque than I am comfortable....concerned I'll strip the hex fitting??
    Sep 2018
    Orillia Ontario
    You have to use heat. A. Propane torch will work. About 30 seconds on each then raise the peg and heat underneath.
    2019 F3S , Blue
