Pass Footpeg -- how do I tighten them?
2020 F3-T passenger footpeg is loose and will not stay in the raised/non-use position. I tried the hex head bolt but cannot budge it. Not sure what to do if I do get it loosened other than add another washer. Any suggestions?
Reason: This is a "How do I?" question not a "How to do:" description
I know on my 2017 F3 limited the passenger floor boards will also not stay upright out of the way. When the floorboard is raised it will rub the panel and if it would stay upright it would scratch the panel. So I just leave it in the down position.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
On our 2016 I took the pegs off and lubricated the bolt and that fixed it.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
My right one is the same way on my 2019 F3-S. I just put a dab of black silicone in the gap to hold it up. If I need service, I'll have it fixed under warranty.
2022 RT Sea To Sky
Highwayman, Did you have difficulty getting the bolts loosened. How did you remove them is difficult?
I can't loosen mine w/o more torque than I am comfortable....concerned I'll strip the hex fitting??
You have to use heat. A. Propane torch will work. About 30 seconds on each then raise the peg and heat underneath.
