Page 3 of 3 FirstFirst 123
Results 51 to 58 of 58
  1. #51
    Dec 2013
    Quote Originally Posted by rtmario View Post
    page modified ...ok now
    Nope, at least not for me!? Now it says 'FORBIDDEN'
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  2. #52
    Danbury Connecticut
    Just a further update:
    I moved into a new house recently and replaced the crappy old garage door openers with newer Genie ones with DC drive and battery backup.
    The new openers would not read the signal from my MoDoor remote.
    Since I had four remotes, I took a chance at soldering wires to the board of one of the new remotes.
    I'm surprised, but happy to report that I was successful and the door goes up and down with a press of the button on the panel, as shown in my previous post.
    https://www.spyderlovers.com/forums/...=1#post1551078
    IBA #47122
    2020 RT Limited Asphalt Grey
  3. #53
    May 2021
    Nevada
    I installed the Spyderpops garage door opener in the place of the blank. I have the BRP auxiliary light (it is plugged and play) no switch needed, comes open with engine start.
    2021 Sea to Sky , cyclops light, front fender light/turn signal, rear run/brake/ turn signal LED strip, BRP floor board light Green
  4. #54
    Mar 2023
    AL
    I know this is an old thread, but what's the thoughts on this aux light? Good or so so?
  5. #55
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by SpyderStro View Post
    I bought an aftermarket LED light for under $20 that fit almost perfectly with slightly better output, so I can't comment on the OEM light, but honestly it doesn't do all that much. It is a little bit better at illuminating the road at night right in front of you and a little better daytime visibility to other drivers. So, for me at under $20, it was worth it, but at the cost of the OEM, I doubt it. However, only you can decide.
    2020 RTL SE6
  6. #56
    Danbury Connecticut
    Just an update, I think I've published this before. I replaced the blank switch with a an additional OEM windshield switch that I've wired up to a garage door opener.
    This spring, I also rearranged the switches into a more pleasing view, with both of the switches that control the heating gear together in the center.
    The garage opener is now in the upper right.
    IBA #47122
  7. #57
    Jun 2016
    indpls in
    i put marine usb with volt meter in the spare hole
  8. #58
    Oct 2021
    Wichita, KS
    Quote Originally Posted by ThreeWheels View Post
    I did exactly the same except my switch is from Mo-Door. It is plain black and only has one momentary position. The center console looks much better with the heat switches together in the center. It should have been this way from the factory.
    Peter Pan has struck again!
