Originally Posted by PMK
Thanks for sharing with us. Stay healthy!!
Eckhard
Spyder RT Ltd, 2011
Originally Posted by jcthorne
Further research in the McMaster Carr catalog with the BRP strut and ruler in front of me, they do not have a strut of the correct length nor correct eye fitting. The BRP ones are custom for application just as BRP told me years ago.
As I recall Mike said the M-C struts were put together from individual parts and pieces, not a complete off the shelf unit. Which way did you come up empty, one or both?
I found the ones from Amazon by Lift Depot noted above worked quite well other than I had to make a spacer for the eye end to accommodate the smaller diameter Spyder bolt. It's a loose fit but for the trunk lid that doesn't matter. Here's what I did. https://www.spyderlovers.com/forums/...=1#post1406313
For sure, for a direct "plug and play" replacement the BRP ones are the only ones available, it looks like.
I did exactly as you did including the trip Napa. I found the perfect spacer at Ace Hardware. It fit just like it was made for it.
Came up empty both ways and the parts list in the referenced post are incorrect length as well.
Excited, I too gave a look at possibly using aftermarket items based on posts here. One post seemed promising, but required buying a series of individual items. Uncertain if the results would be acceptable, I toyed with simply buying oem parts.
Having worked with Gas Springs in other applications before, I knew most likely the issue was pressure loss and not complete seal failure. Opted away from buying any parts, and still never sorted out if the items listed in these Spyderlovers posts would be the equivalent or better than oem.
I bought a prop rod from Pierre at CanamSpyderaccessories.com. It was easier than replacing the gas shock. It looks good. works good. Have not been ryding yet so use has been limited to install but seems ok.
Just replaced my trunk strut with the Amazon part referenced above. No more falling trunk lid for us.
2023 Plasma Red F3 Limited
2020 Ryker Rally.
Here's the quick, easy, and inexpensive solution to a bad trunk gaz shock: Don't replace it! Just get one of the flat, blue, often free LED flashlights from Harbor Freight. It's the perfect size and shape to slip between the trunk hinge and the housing to hold the lid open. It's a good idea to have a flashlight on a vehicle anyhow, so keep it in the trunk and it'll be there for either purpose.
Just received and installed new gas shock for trunk lid. Works great. Ordered from Amazon. Offered by Lift Supports Depot, $44.00. Bruce
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
