2019 CanAm RT LTD Problem?
Hi Everyone.. I am brand new to Can-Am riding!
I have a new 2019 RT LTD... I have experienced one issue which I can't figure out. I have less than 400 miles on the unit and this has happened three times.
While Idling at a stoplight, the unit pops from first into N ( by itself). Once it goes to N, it is extremely difficult to reengage it into first so I can move when the light changes.
Why would it pop into N by itself? How can I stop that? Also, Once I put it into N while idling at a stoplight and I could not move it into first for a couple of minutes ( same issue).
I have also noticed there is a lag when I try to put it into reverse after driving ( I have to try multiple times).
Thanks for any tips/advice so fix this issue!
Anne
Reason: This is a 'How do I?' not a 'How to:' dyi explanation....
Maybe I did? not sure, but I will have to play around with it and try to figure it out, maybe my hand was still on the paddle shifter which is why I couldn't move it back, thank you, I will check next time the sun is out!
Agree, revisit the basics.
Anytime going from neutral to 1 or R, firmly apply the brake.
If the bike is at a light, stopped, but idling in first gear, move your left hand outboard, away from the shifter.
As you accelerate, you must maintain steady or increasing throttle. Decreasing throttle confuses the computer and makes for erratic shifts.
leedlelop, I would add from personal experience that the combo of foot brake applied, reverse button held down firmly (completely) and paddle shifter pushed to the rear can be pain to do at the start. You do get used to it after a bit and the problems go away.
The RT will shift into N or R without depressing the brake. It will not shift into 1 unless you depress the brake pedal.
You sir are correct. Had to go check it out to see. Think I may have formed that opinion because it seems over 50% of the time I shift into reverse I find myself on some level of slope. If it is rolling it does not want to shift into reverse without stopping first, at least most of the time.
You have to be completely stopped for the transmission to shift into neutral or reverse. And like others have said to make sure your foot is on the brake pedal applying pressure to the pedal when trying to shift into reverse.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
I'm going to have to check that out. Seems to me like it will shift into reverse even if you are rolling backwards.
I agree with Mike, and if you remember your riding actions you know it takes just a slight nudge of the downshifting paddle switch with your index finger to shift into Neutral; a thick glove or minor finger flex could trigger a shift. I'll let IMS check to find out if the trans will shift into Reverse if you're rolling backwards, but I tend to doubt it because since it's a constant mesh transmission it seems reasonable to believe it would not automatically shift without the brake being applied before you try to shift. The brake application lock out is to prevent accidental lurches either forward or backward.
It will shift into reverse if moving, just not all the time. Sorta like you can't shift from reverse to neutral without going into first, first. Sometimes if everything is just right, it will. That tells me that altho something is always supposed to be one way, there can be exceptions.
I'm pretty sure you can, but you have to hit the paddle quickly or keep your foot off the brake. If you hold it for a couple of seconds or so it will go direct from R to 1. To do that you must have the brake pressed.
There was a known problem with the 2018 model RTL's with the left switchpack, which is a self contained non maintenance item. A quality control issue I suspect. Mine manifested with a parking brake issue, but I have read accounts of shifting problems emanating from the shift paddle. Pretty sure this carried over to the '19 models.
h0gr1der
