Page 3 of 3 FirstFirst 123
Results 51 to 73 of 73
  1. #51
    Active Member Doug44's Avatar
    Jul 2020
    Decatur, IL
    An update to my post about installing F3 short reach bars on my 2020RTL. After a few weeks and also installing the factory backrest all is perfect for me. Yes it does move the bars pretty close and perhaps just a little high but it is SOOOOO much better I will never look back. Actually if I couldn't have changed the bars or installed some sort of risers I would have just traded the bike off it was that painful for me. Why Can Am continues to install these bars on a touring machine is beyond me, they are more suited to a sport model than a RT.
    Doug 2020 RTL F3 Short reach bars -factory backrest
    K9CRT Ham Radio
    Sold 5/27/2021 Spyder just wasn’t for me. Went back to Goldwing
  2. #52
    Sebring, FL
    Certainly agree with your last sentence, adjustable's would be nice but we know that ain't gonna happen.
  3. #53
    Apr 2013
    Hartsville, S.C.
    Stebrock, I think I might get brave and cut the bar pin and rotate them down just a bit and see how that goes, I'm 5'7". and find them a tad high and close. Did you have any problem removing the allen head bolts? I want to be very careful and not booger those heads.
    With the bars tightened properly I have had no issues with the bars moving out of my desired position. Rock solid.
    On my 2020 I had no problem loosening the bolts with a T-handled allen wrench. On my 2018 F3 I used a heavy duty L-shaped allen wrench and tapped it with a hammer to break them loose.
  4. #54
    Sebring, FL
    Thanks much, good info.
  5. #55
    Sebring, FL
    I did the magic trick, hack sawed the pin, carefully filed it down, so now to ride some and tweeked the bars. I think this is gonna be better than sliced bread. Thumbs up to all the encouragement. Some of 'us' are just overly cautious, cutting, drilling, all that stuff ya can't stick back together if it doesn't work.
  6. #56
    Jan 2016
    ny
    Post F3 Short Reach Bar?
    I am 5 feet tall. Is the f3 short reach bar the one to go with? Any special angle to have it on or
    it fits right in? How do the heated grips come off? Any wire modifications?
    Thanking you in advance
  7. #57
    Active Member justsmile0808's Avatar
    Oct 2019
    Southampton, NJ
    I traded in my beloved 2015 F3-S for the supreme comfort an options of the 2020 RT-L. Being just 5 foot 2, I quickly started to become resentful of my Agador Sydercus 2.0. I wanted to love him, but I just was not comfortable. My feet were dangling - missed the raised bent knee ergonomics that the foot pegs offered me. And the reach to those wide-*ss bars - what was Can-Am thinking?? They want to attract women to the brand - but, unless you are at least 6 foot tall, you will not be comfortable. The brake riser from Lamonster was a God send. I did try his handlebar riser. It did help; however, the bars were still too wide and would cause me pain in between my shoulder blades. Plus, I still could not put my tushy all the way back and sit comfortably in the saddle. Short reach bars to the rescue!!! Had them on my F3-S - and thanks to the awesome posts from our fellow Spyder Lovers - I knew how to find the tricky hidden zip ties to snip and successfully complete the installation myself. Now I just have to wait for Lamonster to introduce some highway pegs and I will be doing one helluva happy dance!! Cmon Can Am - get with the program. If the 2020 RT was your aha moment - then you should've brought the F-3's U-Fit system along with it. Let us choose between floorboards or pegs - or both - and let us adjust them to our own individual comfort level.
    Don't exclude us fidgets - there's a lot of us who love our Spyders!!
  8. #58
    Oct 2019
    Southampton, NJ
    Larsen - a HUGE yes!!! The short reach bars and Lamonster's brake pedal bolster will change your life!!
  9. #59
    Aug 2008
    Maryland
    Quote Originally Posted by justsmile0808 View Post
    Happy to see u are enjoying your RT more. I agree in that it is surprising that the most expensive BRP on-road vehicle line "RT" doesn't provide pegs/brake adjusting. F3 has U-fit and Rykers have a sliding rail system. Go figure. The floorboards are nice but also pegs would be better.
    In BRP's 2020 brochure it shows riders heights from 5' 0" to 6' 3' for F3 - no mention of rider heights for RT. My wish would be for a narrower seating - I don't see any way of modifying it. The seat is thin as it is.
    I am 5' 8" with 30" inch inseam and can reach brake pedal without stretching from back of seat and fully forward in seat can reach to front top of floor board. Not so much height more inseam I would think and where u sit in saddle.
    It is more comfortable for me to sit as far forward in seat as possible with a backrest against me. It is a little narrower there and less stress on my old hips.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
  10. #60
    May 2021
    Texas
    The discussions about positioning have me a little scared. I'm only 5' 8". I did find that BRP has adjustable handlebars for the 2020 RT (and I suspect they will fit the 2021). Has anyone tried them yet? They are on Summer Sale right now. (May 2021) So they have set adjustment positions or infinitely adjustible? Any input would be appreciated.
    https://can-am-shop.brp.com/on-road/...handlebar.html
  11. #61
    Very Active Member MRH's Avatar
    Apr 2012
    Los Angeles and Santa Ynez, CA
    Quote Originally Posted by GaryRT View Post
    Granted that it will cost you significantly more, but if you go with the Helibars there is a near certainty that you can adjust them to find a very comfortable fit.
    https://www.helibars.com/can-am-brp/
    2020 RT Limited in the ultra cool Deep Marsala Dark edition.
    Baja Ron Anti-Sway Bar, LED reflectors, Lamonster USB Charger (and phone mount), Can-Am Low Windshield, X-Creen Tour Variable Windscreen Spoiler Blade, Power Commander, Dilithium powered Flux Capacitor (not yet fully functional).
    Maintained by Lou at Pirate Powersports.
  12. #62
    Mar 2021
    Arizona high country
    I am 5'9" and installed the short reach bars on my F3L. I tried a couple of positions and found the lowest position (lowest heigth and furthest back) was the most comfortable for me. I am leaving on a 2 week trip in June, so will have a more in-depth test than the couple of day rides I have taken. But so far it has definitely helped with the shoulder pain.
  13. #63
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by Larsen View Post
    The handlebar range of adjustment is limited by an alignment pin on the mount that fits in a slot on the handlebars. if you can't move the bars to where you need them the alignment pin can be removed with a hacksaw. Removing the pin in no way prevented me from fastening the bars in place.
    The heated grips are attached to "cuffs" that are attached to the handlebars. Remove the cuffs and the grips slide right off. You don't need to unwire anything. You will have to cut a cable tie to lengthen the control cables. Location of ties are described earlier in this thread.
  14. #64
    Active Member motoguzziman's Avatar
    Jan 2021
    Oconomowoc, WI
    I have a set of short reach bars for sale. I put them on my 2020 RT and for me it was not as comfortable but for a shorter person they may be ideal. If you are interested I will make you a good deal. I never used the hardware so it is new.
    2020 RT , Chalk White
  15. #65
    Active Member mhan's Avatar
    Mar 2021
    Prescott AZ
    I have also gone through the handlebar rabbit hole. Male-5'8" slim build. 2021 RT Sea2Sky.
    1. Stock bars- arms stretched to far, pulling me away from back of seat.
    2. Lamonster 2" riser block - much better but not quite enough.
    3. "Short Reach" bars - To much
    4. 2018 F3, Position B bars #709402241 -- Sweet spot for me.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2021 RTL S2S, BRP arm rests, smart mount backrest, Pedal Commander, F3 position B handlebars, adj side vents.
    2021 Sea To Sky , Green
  16. #66
    Active Member BryanSD's Avatar
    Jun 2018
    South Dakota
    For my wife, we've decided to go the stock F3 handlebar route (#709402241) For those that have swapped the handlebars themselves, how difficult is it? Assume I'm capable but come with lack of experience.
    Also we have a late 2021 Spyder RTL. I heard in the 2020 that some ties had to be removed for the cables to reach. Is that still the case for the 2021?
    2017 Spyder RT Limited - Champagne Metallic Chrome
    - Wolo Bad Boy Horn, SPYDERPOPS Next Gen LED Bumpskid, SPYDERPOPS Double Vision Daytime Running Lights
    2021 Spyder RT Limited - Deep Marsala Metallic Dark
    - Replaced 2021 Stock Handlebars with F3 Stock Handlebars, BRP Adjustable Driver Backrest, Wolo Bad Boy Horn, SPYDERPOPS Double Vision Daytime Running Lights, SPYDERPOPS ""BRAKER BARS" Brake/Run Lights
  17. #67
    Mar 2021
    Prescott AZ
    I had enough slack and did not have to cut the zip ties when installing (#709402241) on my 2021 RT S2S.
    Having removed my handlebar numerous times:
    I found it easiest to remove the handgrip/controls first and let them lay on a blanket covering the console, then unclamp the bar.
    There are 4 cable routing clamps, screwed to the underside of the stock handlebar, 2 on each side. The new bar came without these clamps, but had predrilled holes for them, so they need to be transferred over. You will need to do this first thing as you can't get to them once the handlebar is clamped down.
    Mount in reverse order.
    Very easy operation, took about 15 min.
  18. #68
    Mar 2021
    no need to cut zip ties on 18 f3L
  19. #69
    Jun 2018
    South Dakota
    Quote Originally Posted by mhan View Post
    Thanks for the summary. This give me confidence in doing this myself and I ordered the part. The local dealer thought it could take up to two hours (he wasn't sure if the cable length would suffice) and the potential labor costs worried me.
  20. #70
    Mar 2021
    If it takes them more than 30 minutes you need a new dealer
  21. #71
    Jun 2018
    South Dakota
    Alright folks, I finally got the F3 Stock handlebar put on my wife's 2021 RTL. It took me longer than I had expected as one of the socket head screw that go into the top cuff snapped in the thread when I removed it. I spent part of my day with a screw extractor and then finding a exact replacement screw (at Ace hardware of all places!).
    For the cable reach, I didn't cut the ties for fear of doing more harm than good (such as accidently slicing through more than ties). Has anyone found on the late 2021 RTL that they needed to removed the cable ties when they replaced the handlebars? I'm usually less worried but as this is my wife's Spyder than mine...it's when I don't worry that gets me into trouble.
  22. #72
    Active Member MarkN's Avatar
    Mar 2022
    Mio, Michigan
    Did you use the riser blocks with the F3 bars?
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    2021 600 , Black/Yellow
  23. #73
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I installed short reach bars on my 2021 RT, they were fine , I thought, I put on a back rest and found the short reach bars were too close, the back rest kind of pushes you forward . So , I need to start adjusting the bar or put the stock bar back on.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
