Results 1 to 10 of 10
    Apr 2014
    Warner Robins Ga
    Default Oil warning light comes on
    I have 2009 RS spyder and today while going 55 mph the oil light came on and the spyder running erratic. After shutting off the engine I checked the oil and water and everything was fine. Started it back up and took off went 5 miles oil light came on again. All though the bike seem to run fine, but I did not take any chances and trailer the bike home. The first time I shut it off, there was some minor fluid leaking looked like oil and water mixed together. I tried to run a self test by pushing and holding the mode button with the light switch but no codes where displayed. My dealer is 100 miles from me, so I am trying not to take it in. I am thinking its the oil sensor, does anyone know a way to check or replace the sensor. The bike has 9,000 miles, so I would find it hard to believe that the oil pump would go bad. Plus there is no water in the oil and the exhaust burns clean. Any advice would be quite helpful.
    One last note the oil was changed at 8000 miles with AMSOIL 10w-40 synthetic motorcycle oil.
    Henry Knipschild
    Warner Robins Ga.
    Aug 2013
    Not sure if this helps...
    Located on right hand side of vehicle on clutch housing...
    Aug 2013
    Sensor looks pretty cheap to try... http://www.powersportswarehouse.com/...eria=420256912
    Please don't go by my part number, I guessed at 2009 GS manual trans....couldn't find a 2009 RS.
    Default Little checking..!!
    if you have coolant and oil mix dripping that would be at the water pump. The seals may be failing. Oil light refers to oil pressure. Could be the sending unit oil pump or oil level. If you have no way of checking the oil pressure you have to get it to the dealer. If it is serious it will go orange and limp mode or totally shut down...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    western Colorado
    Quote Originally Posted by SNOOPY View Post
    GS/RS are 1 in the same. GS- (Grand Sport)was 1st then BRP change it RS(Roadster Sport) later
    Aug 2013
    Quote Originally Posted by happyspyder2039 View Post
    Thanks, always wondered about that.
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    That's no BS...
    Aug 2013
    So it's not a BS, it's a GS or a RS
    Apr 2014
    Warner Robins Ga
    I had the same issue on 2009 spyder. when the oil light came on although the bike did not run erratic, I did end up replacing the sensor and it fixed the problem. If you take it to a dealer have a deep pockei at least 200.00. I would check Amazon or Ebay for new sensor if I remember correctly it was under $30.00 and was fairly easy to replace. To make sure google or use you tube,or download a maintenance manual. One of these should tell you how to troubleshoot the oil sensor. The leak could be from the sensor leaking from where it screws into the engine.. Hope this helps
