Results 1 to 18 of 18
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Corona Virus Self Isolation means time to do some work on the spyder!
    Corona Virus Self Isolation Day 1 starts tomorrow, as I found out today I'm off for two weeks. Time to do some spring cleaning in the garage and add some goodies to the Comet! First up, changing out the tricled fender blinkers for the new tricled sequential fender blinkers. While I have the fenders off, I will also paint the calipers 1969 Ford Mustang Grabber Blue.
    Anyone else doing work on their's during the Great Corona Scare of 2020???
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Sep 2009
    La Valle, WI
    We are not off work yet. Only no large events and schools closed. Some bank lobby's are closed
    2018 F3 Limited , Oxford Blue
    Nov 2018
    Claremore, Ok.
    Rumor has it that Oklahoma Borders are closed, but if we can get this damned Portland, Oregon rain, drizzle, and general GLOOM to go away, I know of a little known back way into/outta Arkansas' Twisties.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FINFAN3DP View Post
    That's a really positive way to look at it!
    2014 RTL Platinum
    Feb 2020
    N. Wilkesboro, NC
    The ones you have on there now are the flashing but not sequential ones, right? What they call Gen 1? Do they work well and if so, are you interested in selling them? I have a 2018 RTL and have thought about these but I'm not prepared to pony up the dough for a new set of the Gen 2s.
    Mar 2015
    forrest above Reno, Nv
    These are GREAT. Very bright and eye catching. Our city is closed down also. Putting the back together after installing speedbleeders ( # SB6100 is the correct size )
    Lew L
    2014 RTS , Circuit Yellow
    Active Member KenF's Avatar
    May 2019
    Lacey, WA
    fumble fingers
    2020 Spyder RT Limited
    2020 RT Limited , Marsala Red/Chrome
    May 2019
    Lacey, WA
    Quote Originally Posted by Revalden View Post
    I am in Olympia, WA and that is my normal riding weather.
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by MONK View Post
    MONK,
    Yes, i have the originals on it now. Check out the video at: https://youtu.be/Zfre4wuUYmg to see them. They work great! Just the week after I got them installed they came out with the sequential, and I have been thinking about them ever since. Plus, since i have to take the fenders off anyway, to do the calipers, I figured now was a good time to do pull the trigger. Yes, I would be interested in selling them. However, i just got the replacement kit from Tricled today, so I'm not quite sure what you will need on your end to make them work. Once I put them on I will know more. I will be sure to check back with you then.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Default 2 weeks, turned into 4 weeks!!!
    My off for two weeks, turned into off for FOUR weeks, so I need some more mods to do! Anyone got a tip on some inexpensive mods? Rumor has it, the four weeks might turn into EIGHT!!!!!
    Fin
    Baja Ron Sway Bar
    Key Cover from Ebay
    Oct 2015
    Lynden, WA
    Default Spyder and Working from Home
    One week work at home so far and more weeks at home to come.
    Honey do work before Sypder work. I'm completing the build of a grow room in my garage for
    sprouting vegetables, herbs, and holding bulbs. Lights are installed and sheet rock is almost complete.
    Ventilation will be staged for early next week.
    Next is an oil change and fluid change for the Spyder. Will install speed bleeders ASAP.
    Will also do a suspension grease job. Yes, the 2013 STS has 8 grease zerks.
    Can't think of any additional needed farkles except maybe new front tires.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2019
    southwest oHIo
    Quote Originally Posted by Haze View Post
    I have never thought of maintenance items as farkles.
    My understanding has been:
    Fancy
    Accessory,
    Really
    Kool,
    Likely
    Expensive.
    Dec 2019
    Land of Lincoln
    Oil change and magic mirrors here today. Motul 7100/Outlaw filter if interested. Show Chrome plugs from LaMonster. Jury is out on those with me. They seem OK, but had no trouble with OEM either. Time will tell.
    The Gov of Illinois has a shelter in place order and all non essential businesses should be closed.
    That's a laugh. Nothing has changed, Everything is open, people are out.
    Cant fix ignorance. I suspect worse before better.
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Fin
    If you haven't done so yet a good detailing; waxing/polishing Spyder and wheels, applying something to restore your black trim.
    When I had my RT I installed a LED strip in the trunk with a switch that connected to a USB outlet in the trunk. A very easy and inexpensive mod that was very useful. I noticed it available from some sellers, https://spyderpops.com/rt-rear-trunk...ork-with-2018/ and https://www.tricledusa.com/product-p...ual-usb-plug-1
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Bossier LoUiSiAna
    Lil fun2E3D3FB3-DB15-48E8-84BA-2E6E0D88801D.jpgB03D4A20-C526-47C1-AB8B-7E03BA96310E.jpg D7134A2F-1C8D-449A-96AB-105487595668.jpg
    Found something to help cope with the restrictions D0ED6D4F-A13B-44CC-9EF9-A1B53BD0B4E1.jpg
    Luckily found before thanksgiving was intended as a Christmas gift, but just didn’t happen, mild acquaintance anyway np so mine
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    https://www.spyderlovers.com/forums/...6&d=1585193531
    Actually they are practicing social distancing times two, or 12 feet
    Bossier LoUiSiAna
    Wonder if BRP is gonna cut even more dealers if they don’t get to meet quotas
    Dec 2019
    Land of Lincoln
    Finished my DIY GPS kit.
    12v lighter socket under the seat, LaMonster mount, Garmin LM50 with TaoTronics BT transmitter, in a Cellular City waterproof case.
    Transmits to my Sena in the helmet.
