Results 1 to 6 of 6
    SF Bay Area
    Default Tricled DRL A-Arm lights issue
    Anybody else have this issue, and if so, was a fix available.
    Right side (as sitting on bike) works as advertised and looks great.
    Left side used to work as advertised.
    Now left side is dimmer and rapidly flashes. When I hit the left turn signal it does flash but with no amber. It does not look like the right side when flashing.
I’ve disconnected and inspected the splitter, the module and the OEM connector. I also disconnected, inspected, and reconnected the yellow wire that connects to the left side mirror. Everything looked okay. I still have the same issue,
    My regular lights on the left side work fine. All I can guess is module issue? Any ideas?
    Sadly, at this point, it is worthless. Waste of $150 or whatever it was. I hope Tricled will have a fix (this is my second note to them) but if not, I’ll remove. Any hints on how to remove the glued on LED’s? Heat gun?
    2014 RT-SE6
    Akrapovic Sport Touring 3C Silencer
    High Mount Third Brake Light
    Kuryakyn Black ISO Motorcycle Grips
    LaMonster Spyderdock
    LED’s everywhere!
    Russell Day-Long w/ Backrest
    Seal Floorboards
    Spyderpops Bump Skid
    Spyderpops KOTT Grill (Keep Out The Trash)
    Squared Away Alignment
    Riding taught me why dogs stick their heads out the window!
    SF Bay Area
    Wow! My first note I got a disappointing response.
    Tricled responded to my second note almost immediately. Impressive!
    They said they will send me another LED strip and new module. I'm impressed....don't have it yet but
    I'm impressed!
    Thank you Tricled!
    2014 RT-SE6
    LED’s everywhere!
    Seal Floorboards
    Mar 2013
    I had to replace one of the light strips that stopped working. The vendor sent me replacement strips out at no charge. I just pealed it off without any problem and cleaned the area, and applied new strip.
    They are a company that stands by their products, so you should have no issues getting this fixed.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jan 2015
    southern WI
    I had one strip go out last fall. I just pulled em both off and opted for a pair of driving lights on the a-arms. Much better and they offer "usable light" at night. Yeah, I suppose I could have called them too, but I was considering driving lights anyway. I got my strips from SpyderPops, but I would guess they would have backed their strips as well
    2016 RTS , Pearl White
    Harrington, Australia
    Quote Originally Posted by martiniman View Post
    I'm impressed!
    Thank you Tricled!
    Yeah, the second response is the norm from them, Martiniman. Great to hear you got it sorted
    HeliBars Handlebars
    Kenda Kanine rear.
    Member 101stVet's Avatar
    Dec 2018
    Blairsville, GA
    Quote Originally Posted by Mazo EMS2 View Post
    I have both Tric and Pops light strips.
    Have two issues with Tric, replaced couple days no charge after sending pictures showing burnt out LED's.
    SpyderPops replaced one that was my fault. Phone call, Harvey (Pop) happened to answer....shipped replacement that day.....no charge. Outstanding customer service
