Results 1 to 5 of 5
    Jan 2011
    ft lauderdale
    Default Replace my stock seat on 09 spyder rs
    Looking for ideas for a replacement seat w access flap for fuel, was told of corbin and was wondering if theres any other seating that can do the same
    thks, wheels
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Ultimate has an option for an access port made from an aftermarket gas filler door. Feeling adventurous? Here is a DIY page. the fuel door is the fourth one down. https://www.spyderrt.info/u-do-it
    There are a number of posts under various names dealing with putting in a fuel access door.
    I have also seen, but can't remember exactly where, someone pull the vinyl and padding away and cut the seat pan, reattach the padding and vinyl an a flap is made to get to the gas cap without lifting the seat. The padding and vinyl become the hinge, and they used velcro tape to keep the flap closed.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
    Bossier LoUiSiAna
    Quote Originally Posted by wheels4u View Post
    thks, wheels
    That is an ….. RT seat …. To my knowledge ( back in 2010 ) I'm the only one to put a Gas / Fuel door on an RS type seat..... I used a Fuel Cap from a Yamaha crotch rocket …… When I was Vending I did sell a couple of " kits " for others to put them on their GS / RS seats ……. Mike
    I had a Corbin on my 08. It had the fuel flap...which I thought was very convenient. That said, it may be difficult to find some items for the 09 since it is over ten years old now.
    Checking for used can be helpful if you want a Corbin. New, they were almost $1000. They are also very hard (supportive). You either like them or hate them. I am one of the few in the LIKE column. Had them on both my 08 and the 10. 56,000 Corbin miles.
