Results 1 to 7 of 7
Thread: Manifold
    Feb 2019
    England
    Default Manifold
    Hi all Any thoughts on a tuned round exhaust manifold, coupled to the two brothers system ( with K& N ) filter , must give more power ? Just another thought regards nico 75
    Dec 2013
    It doesn't really matter what you do to the manifold, air intake, exhaust, mufflers, cat converters, or anything else you can swap by unbolting/replacing; unless you get an ECU Upgrade or something like a PowerCommander or a piggy-back chip, you really aren't going to get much improvement in overall power at all!! At best, you might get something hardly measurable, at worst you'll kill some sector of your rev range &/or hammer your fuel economy!!
    So unless you're planning an ECU Upgrade or similar, you're really only playing around the edges & fiddling with noise & appearances, & probably doing more harm than good to boot!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2019
    England
    Default Manifold
    Hi all any thoughts on round tuned exhaust manifold pipe + two brothers system, K &N air filter should give more power ? Regards nico 75
    " NO " …..read post #2 ... ...… Mike
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    The computer and its sensors do a great job of taking any changes it senses and changing the timing, mixture, and other parameters to bring performance back to its’s programmer range. So pipes and mufflers will only change the sound. Only an ECU flash will actually change performance.
    2016 F3-T , Intense Red Pearl
    Feb 2019
    England
    Ok Peter good advice noted regards nico 75
    Feb 2019
    England
    Ok all noted ref manifold regards nico 75
