2015 f3s Tcm codesUO100; UO122 UO155
Dealer is a joke said they had a similar problem with another spider they had and they spent hours doing test after test which BRP told them to do eventually they were just throwing parts on and still never really knew what the problem was basically replace the whole wiring harness and the computers and they’re telling me one of the computers is $1900 if anyone has any thoughts on this Give me your thoughts a real mechanic does not have to throw parts on like a dartboard anybody can do that and I’m not going to be the guinea pig for that because it only has 1900 miles on it but since it is a 2015 I have no warranty
They are all saying wires are bad. Did you have mice get under the bodywork while the bike was in storage? Check all plug connections and battery connections. Could be the plug on the ECM is loose or a bare wire. Check the battery to see if it is still good. Connections should be clean. Take it to another shop.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Did someone do work on it before this happened?
2016 F3 Limited
2019 Ryker Rally
2020 CSC TT 250
