Results 1 to 10 of 10
    Aug 2019
    Minnesota
    Default Fobo on F3T air shock clearance
    Has anyone tried a Fobo on the Schrader valve for the air shock that is under the seat? I have a ‘19 F3T
    I am wondering if there is enough clearance to accept the extra height.
    Thank you
    ba
    2019 F3-T Liquid Titanium
    “we are all products of those to whom we have chosen to listen”
    2019 F3T , titanium
    Mar 2017
    If it won't, you might wanna try one of these from the internet. to see flexible valve extender
    Jul 2019
    Topeka,ks
    Mine works great on my 2019 f3t, no problems
    2019 F3 t , Black
    Aug 2019
    Minnesota
    Quote Originally Posted by Whiz11 View Post
    thank you Whiz11
    I am ready to order 2 sets of 2.
    I went out to look at the valve stems to see how they will fit and I noticed that they are really short. I'm not sure how i am going to get the Fobo to screw on without interfering with the wheel. The stem looks recessed. I didn't look at the rear so I'm not sure what the deal is there.
    Did you have to have new valve stems installed?
    Thanks again,
    ba
    2019 F3T , titanium
    Active Member funon3's Avatar
    Mar 2010
    Indianapolis, IN
    Front valve stems are very short and I installed 3/4" valve extensions which solved the problem and worked great with no effect on tire balance. Rear tire was fine as is with no extension.
    My new ride is a 2017 F3-L: BRP drivers backrest, F4 21" tinted shield w/vent, Lamonster fog lights, TRCLED cyclops light, red/black carbon fiber tank protector and dash kit from Wrap-My-Spyder, FOBO tire pressure monitors and more farkles to come.
    Mar 2017
    Quote Originally Posted by arachnyd View Post
    thank you Whiz11
    Thanks again,
    ba
    One set of four would get you a single sensor readout and save some bucks for gas.
    Aug 2019
    Minnesota
    Quote Originally Posted by Rattlebars View Post
    Is there a set of 4 Fobo 2 Bike? I only saw sets of 2 and 3. Fobo csr told me to get 2sets and choose quad in the app.
    Thanx
    ba
    2019 F3T , titanium
    Mar 2017
    Get an auto set.
    Aug 2019
    Minnesota
    I installed my Fobo today. Have not ridden with them yet, but got them set up with the app.
    I used the configuration in the app that is reverse trike + air shock.
    I think I am going to like these.
    Thanks all for the help, I appreciate it.
    ba
    2019 F3T , titanium
    Mar 2017
    Today I installed these on my F3T using R.L as the shock bag and R.R for the rear tire. I have not ridden on the road with them but I do know they read 2-3 pounds low for each schrader. All sensors cleared under the seat and on the rear wheel and I had already added ˝" extenders on the front rims. Thanks for the great Idea!!
    to see on Amazon
