Results 1 to 18 of 18
    Active Member swrafey2000's Avatar
    Apr 2008
    Lakeland,Fl
    Default Evoluzion air filter
    I have a 2008 GS with a Evoluzion air intake. Does anyone know where I can get a new filter element or a whole new air intake.
    Quote Originally Posted by swrafey2000 View Post
    I'm not familiar with what your intake looks like ….. It is cleanable like the K&N type ???? ….. if not I would see about getting one ….. if you could provide some pics that would be big help …. On my 08 and 11 RSS I trimmed the rubber snorkel and added a piece of 4inch alumin. dryer hose to the end .… I then connected the hose to the right side air intake …. this provide much cooler Air to the Throttle bodies ….. Mike
    Apr 2008
    Lakeland,Fl
    I can't post pictures because the filter element is completely disintegrated. Evoluzion was the first one to come out with a filter that replaced the whole air box back in early 2008 but they went out of business in 210. I got this one used from Docdru in 2009. Does anyone make a replacement air intake for a GS.
    Aug 2007
    Greeneville, TN
    Evoluzion went out of business in 2011 (I think that was the year). In any case, it was long ago. Is this the drop in filter for the stock air box? Or is it a stand alone unit like the JT kit?
    Apr 2019
    Florida Swamp
    Have you looked on ebay?
    2019 F3-S , Black & Silver
    Apr 2008
    Lakeland,Fl
    Yes, no luck. I've had my GS since it was new. I replaced the old air box with it back in April of 2008 so I would say I got my money out of it. Hard part is having to change it. I have a adjustable fuel pressure regulator on which is to tall for the stock air box.
    Apr 2008
    Lakeland,Fl
    It's a stand alone. Is JT' similar to the Kewlmetal one? The one Evoluzion one is oval foam filter that clamps over a billit aluminum duel velocity stacks.
    Mar 2018
    Pennsylvania
    Does it look like this? If so these are available on ebay.
    Apr 2008
    Lakeland,Fl
    It's pretty close. It might work. Do possibly have a link please.
    Mar 2018
    Pennsylvania
    Do a search using the following words: K&N Style ( R-0990 ) AF0990
    Mar 2018
    Pennsylvania
    Here's what I did. I purchased the bottom half of an air box from ebay. (See picture) You can find these reasonably priced. Cut out the part with the tubes that mounts over the throttle bodies. I shortened the air box tubes and slipped the above air filter into them. The air box tubes are slightly larger, therefore the the air filter slips into them. The fit is snug, but clamps can be added.
    Mar 2008
    Hesston, PA
    I "THINK" that there was a Buell or maybe it was Aprilia motorcycle that used a "souped up" version of the Rotex 998 engine...(around 140 HP) Maybe it used the same air filter that Evoluzion offered...I had their air filter, fuel pressure regulator & oxygen sensor eliminator on my 2008 GS but its long gone...larryd
    Apr 2008
    Lakeland,Fl
    That's what is on mine.
    Aug 2007
    Greeneville, TN
    I am not familiar with the Evoluzion air intake system. But it is very possible it is simply a manifold designed to mate up to an off the shelf air filter. In which case, you should be able to find a replacement air filter for it. If that is what you are looking for.
    Jul 2018
    Lake Stevens, WA
    or replace it with a JT - jt air filter for can am spyder
    2009 GS , MSD wires Red/Black
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by CANUSASwede View Post
    I have to say that I really like my JT filter. Highly recommend the optional sound reduction component.
    Mar 2008
    Hesston, PA
    I just looked in my garage AND I have a BRAND NEW ONE IN THE FACTORY SEALED BAG from Evoluzion along with a NEW pressure regulator kit...(complete race air filter kit) I'll PM you my contact info...larryd
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    WOW! Lucky OP
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
