2020 RT rear tire size
Is the rear tire the same size as previous years of the rt on the new 2020?
2014 RT-S Pearl White
Ozzie Ozzie Ozzie
Yes.
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Yep. However, changing a rear for the home DIYer is going to be a bear. The new mudflap is huge and hangs waaay down and will definitely get in the way.
2020 RTL SE6
I was wondering mainly because I have a brand new ready to install rear tire in my garage. If all goes well, I’m planning to pickup a leftover 2020 at the end of season, so I will definitely hang onto the tire I have.
The mudflap is the same as the F3L. Just lift rear up higher. Mine wasn't in the way at all. You drop wheel straight down and out to the side. Pretty straightforward.
Yep that's what I do.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
