What tools
If you had space for a medium roll up tool bag what tools would you carry in it road repairs?
Appropriate size Torx bits & driver, mini air pump & plug kit, digital tire gauge & flex extension for the rear wheel, appropriate metric box/open end wrenches, a few zip ties of assorted length, some Gorilla tape, a gremlin bell and credit card.
We've taken all this plus other stuff we thought essential in two longish road trips and didn't use any of it. Our Spyders are very reliable or we're lucky or both.
I carry the tool bag that came with the Spyder, a T handle torx, tape, wire, crimp on connectors, a tire plug kit and tire inflator and a Good Sam Premium road service card and a credit card a flexible tire gauge and a flexible adapter for the rear tire.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
This and a tire plug kit.
Key word for a Ryker is "space."
Wheel skt / Tommy bar / small ratchet with some torque bits. / wash leather / torch / first aid little driver . I carry these + a small map to back up my sat nav. Regards. Nico 75
Tire repair kit, credit card, cell phone. Same stuff I carry in my truck and wives SUV.
Tool kit
When I traded in my VSTAR for my 2019 F3Limited I transferred items from the Star to my Spyder. TodayI found in one of my transferred bags a spanner wrench (used to adjust the rear shock, which I never did) and I’m pretty sure it belonged to the VSTAR.
But to be sure, I wanted to check that it doesn’t belong to the spyder (or can even be used on the spyder) before I remove it from the bike. I don’t want to carry a tool around that is not needed.
Poasttown
The tool kit, and the "Tool Kit" info (p.43) in the Owners' Manual leave lots to be desired, both in quality and quantity. I'm thankful for this thread and the suggestions herein, however being new to the Spyder (March 2020 RTL) I'm anxious for tons of info on the use and care of "Candy," but as mentioned there's "lots to be desired" when it comes to what services I can do at home or what I should anticipate when out riding? Like - what are the appropriate sizes for Torx bits, what are spanners, or Tommy Bars, or Gremlin Bells? Yes, if I have to ask, then I probably won't know how to use them anyway. Any suggestions about where to go for tutorials on this "tools" subject would be greatly appreciated.
Lotsa 10mm sockets, 1/4" and 3/8" drive and a ratchet for each, and aforementioned torx bits. And since we all eat at unknown restaurants, toilet paper, ADULT DIAPERS, small squirt bottle for accidents, Pepto tablets, Imodium, Tylenol, Aspirin, First Aid kit with clotting stuff, sutures w/needles, Steri-Strips, blood plasma, transfusion stuff, alcohol wipes, and lotsa drinking alcohol to numb the pain, prescription pain killers w/prescription from Dr. so if you're fuzzed you're covered. and a small trailer to carry all this …,....,.,_ Can you tell my wife is a Nurse Practitioner?
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
For me, it is a couple credit cards and a mobile phone.
I am not a mechanic...so if do do happens, I am in a bit of trouble.
The Spyder is a bit technical, and most of the hand tools that one would need...are not practical anyway.
Most of the above information is good though, if you bring tools along just in case.
For me, reliability has not been an issue. Now going on 150,000 + Spyder miles.
SpyderLovers Sponsor
That answer is best answered by your mechanical ability, If you are a good mechanic
you will already know what to take but if you are a tinkerer, I would take screw drivers, a small set of metric wrenches,
plyers, allen and torx wrenches, a tire plug kit, flash light. I am sure some one else will add to this.
Originally Posted by Motorcycledave
That answer is best answered by your mechanical ability...
Bulls-eye! Speaking for my '14 RT-S and my mechanical ability that far exceeds what I would do to my Spyder on the road, in addition to the OEM tool kit that isn't much use except for the screwdrivers, I carry a 1/4" drive ratchet, long extension, 7 & 10 mm sockets, T25 & T30 Torx bits, 12 mm open end wrench, small crescent wrench that will open to at least 12 mm, Leatherman type tool, and the usual tire plug kit, emergency air compressor and assortment of sip ties, electrical and duct tape. Since my headlights and fog lights are both LED's I carry one spare halogen headlight bulb as that is the most serious problem could I see myself doing on tour other than a tape and patch job 'til I could make it to a dealership.
I carry a lot of the same stuff as most others (but not the adult diaper guy)and also 2 rear axle wrenches so I can adjust that wheel in case the belt decides to start running out of alignment or if I had a blowout.Dont know how id jack it up Im working on that.
: 2017 RTL ORBITAL BLUE
On long road trips, we divvy up what each of us carries so we only need the one 12 volt air compressor, not 10 of them, etc etc..... since most of the other guys are much more proficient mechanics than me (and one is a retired mechanic who also owns a spyder...YIPPEE!!) they have most of the tools, and I pack extra beer
You can't get there from here....
Mods and Tweaks:
Showcrome Trunk Rack
Showcrome LED Trunk Light
Garmin 390LM
Spyderzone Floating Hiway Boards
Spyderzone Mount Dash Bracket
BajaRon Antisway Bar
Showcrome full-size brake pedal
Spyder-2-Go Driver Cup holder
Ram X phone mount
SpyderExtras 12 volt Docking Station
BRP Driver Backrest
Monster 4K Action Camera
Spyderzone LED Fender Mount Spotlights
CASA LED Headlights and Foglights
When I bought my Ryker, I didn't get the screwdriver that was supposed to be the 'tool kit'. So I didn't expect a tool kit on the F3 Ltd; was surprised to see on page 50, mention of the location of the tool kit. So I looked.....yeah, there's a place for one but nothing there. Call to dealer on Tuesday to see what's up.
2020 F3L; gone but not forgotten are all the good miles!
